Home | Mitsubishi | WS-65809 65 in. Rear Projection Television | CONTINUOUS BLINKING GRE...
Mitsubishi WS-65809 65 in. Rear Projection Television
Problem for Mitsubishi WS-65809 65 in. Rear Projection Television
CONTINUOUS BLINKING GREEN LIGHT. tV will not turn
By lylesol on Oct 16, 2009
CONTINUOUS BLINKING GREEN LIGHT. tV will not turn on. what can we do?
Best Solution
posted on Oct 16, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 855 votes
THIS IS MY STANDARD ANSWER TO THIS QUESTION==SOMETIMES PEOPLE DO NOT TRY THE EASY POSSIBLE REASON--IF YOU HAVE ANY QUESTIONS LET ME KNOW---IF THE ANSWER TOLD YOU something you did not know--rate the solution----
ONLY 1 of 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mitsubishi WS-65809 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65809 65 in.
Do you recommend Mitsubishi WS-65809 65 in. Rear Projection Television?
Answer
Answer
There are many lines going through the tv picture and they flicker and move horizontal
Answer
shoot off tech said color bulb burnt with a little water damage
Answer
My WS65809 Mitsubishi shuts itself off randomly. When I turn back on sometimes it shuts off... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-65809 65 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
