Question about Uniden BCD996T Base Scanner
Uniden bcd996t do i need a driver to load my scanner. my lap top dose not see the scanner through the usb cable
    Scholar:
  • 36 Answers
Hello wfd88,
You need a copy of Uniden Advanced Scanner Director software. You can download the software from http://www.uniden.com in the Customer Service Downloads link.
Also, as a reminder, you need to use the cable supplied with the scanner and, if I recall correctly has a Uniden custom connector on one end and a serial connector on the other. If you do not have such a cable, Uniden sells a USB to Serial converter under the model USB-1.
If, during transfer, you get an error message, reduce the scanner’s serial port speed setting and start again until you get reliable, complete transfer of data.
Let me know if this helps.
cancerags
Posted on Dec 28, 2007
I need to delete one frequency at a time from a uniden BCD996T scanner.
it scan run all nuber threw all exct there 3 numbers wont scan it like there stuck they wont move at all then weather radio come on and it turend off
t
Feb 24, 2014 | Uniden BCD996T Base Scanner
How to edit a frequency on a bcd996t
if you don't have the manual, go to the UNiden site and download a copy
Sep 12, 2012 | Uniden BCD996T Base Scanner
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Unable to program trunking after uniden download was completed
I would try redownloading and reflashing the firmware on the scanner. If this doesn't work, you may want to try downgrading to the previous version of the firmware. If you are unable to redownload the firmware from Uniden, there is a Yahoogroup dedicated to this radio.
http://groups.yahoo.com/group/BCD996T/join
Also in the files section, there are older versions of the firmware.
Hope this helps!
Feb 10, 2010 | Uniden BCD996T Base Scanner
My pc is not recognizing the scanner
In your printer and fax folder you probably have more than one printer installed and your default printer is not the one you just installed, Select the printer you just installed and set it as your default and try again
Jun 19, 2009 | Uniden BCD996T Base Scanner
I need to program my bcd996t police scanner.
I have uploaded a pdf format manual for you if you do not have this.
http://files.hpifdesigns.com/pdf/bcd996Tom.pdf
also I hear there is a cd that comes with it too this might be handy to locate as well.
if you are wanting police frequencies please do a search for them on google.com eg. "las vegas police frequencies" ect and you should find alot of codes for your area.
Aug 02, 2008 | Uniden BCD996T Base Scanner
Uniden BCD996t
I went through the manual page by page and found no info on how to doa complete system reset.You might join the BCD996T Yahoo user group and ask your question there or look through this easier to use guide I found on the internet.(http://marksscanners.com/996/996.html)
May 07, 2008 | Uniden BCD996T Base Scanner
1.2.3.Guide
Try this link: http://myweb.cableone.net/marksscanners/996/996.html
The scanner memory is different than others in the way that it is organized. But the basic syntax is: SYSTEM/GROUP/CHANNEL.
Don't give up. It's a great little scanner.
Sep 07, 2007 | Uniden BCD996T Base Scanner
Uniden BCD996T Base Scanner Logo
347 people viewed this question
Top Uniden Radio Communications Experts
Steve
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
