Question about Denon Audio Players & Recorders
Denon Receiver flashed PROTECTION and stopped working after plastic smell
My Denon AVR-1200 Receiver stopped working after I determined that one of the speaker wires were crossed (they wires had been pulled accidentally from the speaker and were touching together). A burnt plastic smell appeared and the receiver stopped working, it just flashed PROTECTION and was rather overheated.  I tried unplugging everything and cooling it down and tried reseting it, but nothing.  I looked for blown caps or other obvious visual problems but nothing.  Is it something that is easily fixable or worth getting fixed?  This is the first problem in 11 years, it worked flawlessly throghout.
Thanks
Mr. B
  • Babis Dec 28, 2007
    What are my options as far as the best thing to do with this receiver?  Fix it, post it for parts, toss it? Or any suggestions?
    What would it cost to fix and what is its worth today, fixed or not?
    Thanks
I just had the same thing happen to me what did you do to fix it?
Posted on Jan 04, 2008
Protection displayed on avr 1200 when turned on
Usually this indicates a short somewhere in the speaker wiring.
Dec 04, 2016 | Denon AVR-1200 Receiver
How many Watts is the denon avr 1200 receiver
GOOGLE IS YOUR FRIEND - try that before asking questions. Just type that info in a Google search and off you go.
Jul 20, 2013 | Denon AVR-1200 Receiver
Denon avr-1506 will turn on then flash red and turn off... how do i make it stop or fix it??
In most AV receivers if the standby light flashes after turning on and you don't hear the regular click of the relay engaging after 4 seconds, indicates an output short or amplifier failure. The protection circuit prevents any further damage by not turning on system.
You will need professional help to fix this problem because even to a electronic enthusiast the construction of a typical AVR is not service friendly.
Jul 01, 2011 | Denon AVR-1506 Receiver
I have an avr 4800, and eveytime I raise the volume to -21 or higher it goes into protection mode. can you help? my zipcode is 60184
http://www.retrevo.com/support/Denon-AVR-4800-Receivers-manual/id/363ag816/t/2/
I'd treat this symptom as "DISPLAY not lit and power indicator is flashing rapidly." under Troubleshooting on Page 60.
and I'd evaluate the speaker load you're presenting to make sure it's effectively higher than 6-0hms per speaker channel.
Jan 11, 2011 | Denon AVR-4800 Receiver
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
forfrance@hotmail.com
Apr 12, 2008 | Denon Audio Players & Recorders
Receiver in Protection Mode
Electronics like a receiver are so sensitive to power surges. I'm sorry to say that it's most likely unrecoverable, especially if it wasn't plugged in to a surge protector. Even if it was, they don't all protect 100% from surges. :-/
Apr 24, 2017 | Denon AVR-1200 Receiver
AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Dec 28, 2007 | Denon AVR-2106 Receiver
452 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
