My dc7100 has a compact power supply with proprietary 24 pin plug. Pretty sure power supply is non-functional (shorted green to black and fan didn't come on). Is it possible to rewire a conventional ATX supply with this smaller 24 pin plug? I need to know pin outs? Thanks
My research indicates that your power supply uses a custom pin-out and that a standard ATX supply cannot be adapted to it. I did, however, locate a new (pull) power supply for $59.95 -- follow the link below. I hope this info helps.
wont read any burnt dvd just hangs for a bit then nothing i open the cd drive to see if there are...
(More)
wont read any burnt dvd just hangs for a bit then nothing i open the cd drive to see if there are any files but there is nothing any ideas?
I have a Compaq Presario CQ50 and the built in SD card slot is no longer responding when I insert a...
(More)
I have a Compaq Presario CQ50 and the built in SD card slot is no longer responding when I insert a card (the light doesn't even blink). I went in to device manager, but don't see the driver. Where do I get the driver, or is there some other fix besides reinstalling it?
I find that I cannot navigate the program. I went from a concord that you chose your book, typed in...
(More)
I find that I cannot navigate the program. I went from a concord that you chose your book, typed in the topic and then printed it. This edition is so complicated that I find that I am at a loss before I get started. It would be helpful to me, if there was a more explanatory manual. Patrice triciawhit@sbcglobal.net
I cant perform Biosflash whatsoever,not from USB, diskette or Cd, tells me it is corrupted hence i...
(More)
I cant perform Biosflash whatsoever,not from USB, diskette or Cd, tells me it is corrupted hence i cant adjust any settings in setup or even load defaults and save, tried everything in vain am frustrated, should I get another motherboard, WHAT COULD HAVE CAUSED ALL THIS? MY NAME IS LABAN SHIKUKU I AM LOCATED IN KENYA,EAST AFRICA, MY E-MAIL ADRESS IS LABANANDISI2006@YAHOO.COM
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
