Ok, so I just got a 8x6 Genius MousePen Tablet and just figured out how to install it in Vista, but now when I use my pen it won't reach the far right side and part of the bottom. When I use the mouse it does work. My latop's resolution is 1280x800 but when I set it to 1240x700 it does work like it should be, so I'm guessing that's what's wrong. I've messed with the settings I'm offered by the MousePen series thing that comes out in the inferior right corner of the screen (where the date is) but nothing solves my problem. So what can I do?
Do this open tablet setting( the one beside the windows time) go to pressure, on the sensitivity move a slider a little untill the apply bottom turn on, click on apply, (Not OK Just APPLY) then open a graphic software, for me photoshop is the choice, after photoshop comes up you can return to the mouse pen setting window and at this time press OK, you will have full screen work area after that, even when youclose your photoshop, hope be helpful,
Also cannot use with multiple monitors. pen only works on primary display and there is no setting to fix.
might have to RMA and buck up to a Wacom....
i have same roblem too. some one helps
I have the same problem as the original poster. I have tried the first solution and it does not work. Can someone offer another one?
