Question about Sony Cyber-Shot DSC-S40 Digital Camera
Multiple image capture
On occassion, and for no reason I can see, the camera will take 3 to 6 images at one time. You get a stop action of someone walking across the room or 3 or 4 pictures of someone just sitting in a chair.
Anyone have this problem and have any idea how to fix it?
  • 477 Answers
Make sure your motion shots is off. check out the camera for anything that looks like 3 squares stagering down. if that is on this will cause your problem. it need to be set on one square only for single photos.
Posted on Feb 20, 2008
My LGfront end loader washing machine is shaking so bad it actually walks across the laundry room 3 -4 feet
I had the same problem when my LG WD-8074FHB was new. LG recalled them and put a larger weight in them. The weight is a hollow piece of plastic filled with concrete in the top of the machine under the cover. It stopped it moving around the laundry.
Mar 04, 2014 | LG WM1814CW Front Load Washer
Frigidaire tumble action washer will not agitate or spin. Drain water fine. One of the shock absorbers is broken. would this be the problem? The belt is fine.
Yes there are several balance switches in the unit and if the shock is broken at least one switch has been activated. If you were to some how bypass the switch the unit would be very dangerous to even be near during the spin cycle as it would try to walk, tumble or jump across the room! The switch is a safety feature for all concerned.
Please get your machine repaired.
Thanks for using FixYa!
Mar 10, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Pokemon platnium stopped working right because of action replay
you must ahve glitched your game when you entered the room. your not supposed to enter places like that with the AR because it will glitch up. sorry to say but, New Game.
Jul 27, 2009 | Datel Action Replay for Nintendo DS
Blurred images
Any number of things.
Low ISO. No Flash. No tripod. Too little light. No "shake" correction on the camera.
Depending on the goal of the photo, you may wish to use a tripod. Or use the flash. Or use a higher ISO (400+). Or any combination of these.
The easiest thing to do would be to make sure you use a flash. If you're trying to take a photo of something without the flash, you'll have to use a tripod. And even then, if something is moving fast through the frame, it'll likely be blurry. You simply need more light.
If you're new to digital cameras, I recommend the automatic settings. There's an "action" mode which usually has a man running as an icon. Or someone in motion. Some cameras even have settings for use at night or in darker rooms. Try those.
If you feel comfortable, you could manually bump the ISO up to 400 and try again. Your photo may be a little "grainer" and will probably look a bit ugly blown up much over a 5x7, but for 4x6 or anything online, it should be fine.
Feb 27, 2009 | Polaroid i830 Digital Camera
I have a fujifilm digital camera, every time i take photos i download them onto my computer using my usb cable , everything works fine. Suddenly for no reason it has stopped working, the images on the...
I would try to replace the usb cable, but it sounds more like a software problem not the camera. If the camera shuts off during transmission it will keep the pictures from transporting.
Jul 16, 2008 | Cameras
LCD screen dark and jagged lines
my nikon D80 did the same thing, had to replace the LCD. Their screens are very pedantic and screw up for no apparent reason, they also dont have as much shock resistance as the rest of the camera, as Ive learnt from expensive previous experiences....
Mar 27, 2008 | Nikon Cameras
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Sep 26, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Picture has a blur image
i think the problerm is not your tv but the reception on your free view
Jul 14, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Dark Images
Recently this happened to me just as I was walking in a church to shoot a wedding (major bummer). I had to rush and get my film backup for this. Anyway, this problem has ocurred with several examples of the S2 pro including mine, one other than mine that I know personally. The problem is the sensor. I quickly shipped to Fuji and they fixed the problem. I just got my camera back and so far it is working fine. Time will tell. I had to pay for the shipping only and turnaround was quick (1 week). By the way the camera was already out of warranty, but they gave a 3 month warranty after the repair.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
