I suspect that your problem is not in the bios, instead with jumpers.
IDE reqires jumpers on the back of drives to tell the computer how to use the drive. if you removed the 360 gig hdd (which was robably the primary drive) you will have to now make the disc drive primary.
However now there is a feture called "cable select" wich detects all hardware on the IDE controler and assigns them appropriate properties, this is a good way to do it because jumpers are a pain in the rear end
