Question about Bose 901 VI Main / Stereo Speaker
Bose 901 connection to Pioneer VSX-917v Receiver
Replacing my old Pioneer VSX receiver with the new VSX-917v, and it does not have a "Tape 2 Monitor" connection. What would the correct connection be?
  • jmartin7 Jan 02, 2008
    After speaking to Bose directly, I've determined that the 901s won't work with the VSX-917v. Bose recommends a few specific receivers that will work, and all are in the $4,000+ price category. Those $$ are not in my budget. The VSX-917v has one pre-out designated for sub-woofer use, and I'll probably need to use that for the sub-woofer, so I'm considering different speakers for this HT application, and will use the 901s for a stereo-only setup using my old receiver.
    Thanks for the suggestions and help. I was in a bind and trying to get things set up before a New Years Eve party....you helped guide me into an interim solution.
  • PATCOMAN Feb 13, 2008
    You can use a pre amp in and out circuit also in place of a tape monitor loop. Yamaha rx 777 has it. I have it. WORKS WITH 901'S. patcoman
    Novelist:
  • 148 Answers
Any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Posted on Dec 28, 2007
  • MARK  EVANS
    MARK EVANS Jan 02, 2008
    i suggest the klipsch speakers.
    we sell and install them in almost every home theater application for their brilliance and price. very cost effective. unbeatable sound, amazing lows. my home theaters (i have 3 at home) all are klipsch driven. not power hungry either.
    for more in info: markevansmarkevans@hotmail.com
    good luck
    mark
I'm connecting Bose 901 speakers with an Active Equilizer hookup required to my new Pioneer VSX-520. What in/out puts should be used ??
The solution to using 901's in a multichannel rig works best when you have individual Front Right and Left Pre-Outs but this receiver doesn't have them so a compromise is in order.
First some background.
The use of 901's Active EQ (or any external processor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's.
http://www.retrevo.com/support/Pioneer-VSX-520-K-Receivers-manual/id/23653ag911/t/2/
This works for all models of AV receivers when you want 901's as Front L&R speakers...
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them, in your case maybe the CDR or DVR/VCR outputs.
On many AVR's, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others (yours), you have to borrow the signals from a typical CDR or DVR/VCR Output RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won
Feb 13, 2011 | Pioneer Audio Players & Recorders
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer ' eHow.com http://www.ehow.com/how_4813156_install-bose-equalizer.html#ixzz19vfsJTQu
    Jan 03, 2011 | Bose Audio Players & Recorders
    I have a Bose 901 Series VI speaker system & have recently purchased a Pioneer VSX-1020-K AV Receiver. How do I connect the 901's EQ to this amp. I believe the only option is the CDR/TAPE IN/OUT...
    This receiver has no pre-amp outs to drive the required separate amp the 901's need for you to continue to have multichannel digital audio. The reason: activation of a tape loop disables digital inputs. But they DID give you Front Height. Oh boy.
    Sep 15, 2010 | Bose 901 VI Main / Stereo Speaker
    Pioneer vsx 1020 K receiver. I connected the bose 901 eq to the tape in and tape out but it doesn.t seem to be compatible.
    It would be compatible if you ONLY listened to stereo ANALOG sources on ONLY Bose 901's. Engaging any device in a tape loop automatically disconnects digital sources. Bose Active EQ is not intended for anything BUT Bose 901's. The sub could be destroyed by it.
    Lacking appropriate Front Left and Right volume-controllable pre-outs on the 1020k, you can't use the 901's for multichannel or digital source material unless you accept a severe compromise and get a separate amp for the 901's borrow mixed-down stereo from the Pioneer's Tape Out, run it through the Active EQ to the new amp and manually manage the external amp's volume.
    You need Front Pre-outs.
    Jul 20, 2010 | Bose 901 VI Main / Stereo Speaker
    How to install bose 901 eq to my pioneer vsx-1019ah-k
    Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
    Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
    Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
    I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
    Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
    So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
    Oct 24, 2009 | Audio Players & Recorders
    How do I connect my Bose 901 to my Pioneer VSX-515. I have used the eq to the tape in tape out as instructions tell me to do, but do not have a "tape monitor" button on my receiver. I get sound from the...
    I'm not sure that receiver is compatible with outboard EQs like the 901 EQ. This receiver is also not on Bose's 901 EQ compatibility chart, so it's possible that this is not going to work at all. You could call Pioneer and ask if this receiver is compatible with ANY outboard gear (such as EQs, compressors etc) but I don't think it is.. The tape in/ tape out I think is only for 1 source.. That's the problem with new receivers, they expect that nobody will want to connect any external gear (like back in the day) because everything is built in.
    Jun 11, 2009 | Onkyo TX-SR705 Receiver
    Bose 901 series speakers to Bose 901 Equalizer
    There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
    Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
    Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
    Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
    Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
    Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
    Pioneer vsx 90txv and bose EQ
    I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
    There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
    The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
    * I can't find your exact manual so I have to extrapolate features.
    I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
    A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
    You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
    ** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
    Bose EQ Amplier OUT >>> new amplifier IN.
    Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
    *** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
    Feb 01, 2009 | Pioneer VSX-90TXV Receiver
    Bose 901 equalizer hookup
    how do I hook up the bose 901 EQ to a yamaha DSP3090??
    Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
    Bose 901 VI Main / Stereo Speaker Logo
    857 people viewed this question
    Top Bose Audio Players & Recorders Experts
    jjcicala
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
