Question about Philips Magnavox 27MS343S 27" TV
Shadowing in picture
I have Magnavox model MRP43 that has now got a distinct "shadowing" of objects showing on TV
    Sergeant:
  • 319 Answers
Try replacing the RF cable going from the cable box to the TV and/or AV cables. I've found that the RF cable from the cable outlet in my place to my TV caused shadowing. If that doesn't work it could be something in the cable outlet itself. I am assuming you aren't using a TV antenna.
Posted on Dec 31, 2007
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Hitachi 61" TV-objects on screen have yellow shadowing
The convergence circuit of the TV is causing this. You will need to have your convergence output ICs replaced. Expect to spend $350-450 to have this issue fixed.
michtech
Feb 12, 2009 | Hitachi 60UX58B 60" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Instruction Manual for a Magnavox Rear Projection TV Model MRP43
If you go to magnavox.com they have a pdf of the original owners manual.
Nov 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Shadowing of projection T.V.
if it looks like a 3-d you need to replace both your STK-392-110'S IC's and you can get them at the following link with step by step picture installation instructions as well as free online tech support
http://servicemanuals.vstore.ca/
Apr 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi Projector Screen
does it look like this picture? you will have to scroll down a bit
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
My tv wont turn on
that model number isnt coming up as a valid philips model
Oct 13, 2007 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
