Back to:
Tags:
Jensen KA3 Car Audio Amplifier
Both green and red ligt or on my jensen ka3
posted by locokinto on Dec 28, 2007
both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i have no idea what the red light stands for so can some one help me out plz
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 28, 2007
Not Rated (0)
pbabin
Rank:Guru Guru
Rating: 89%, 261 votes
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on both green and red ligt or on my jensen ka3:
I don't want to Accept this solution
Can you Help with these Car Amplifiers problems?
Car Amplifiers
burned 2 circurt on the power cable side on the top and on...
Car Amplifiers
I have no output from this mixer and the phantom power led...
Car Amplifiers
need help with installing this amp
Car Amplifiers
code for a remote control universal for a pelisys tv
Car Amplifiers
need schematic
Loading problems.
Repair Service
Find Car Amplifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
