Question about Canon PowerShot A85 Digital Camera
Constant flickering Screen flickering - when taking pictures even though screen flickering they turn out ok. When taking video though you see the flickering on the video once played back. Batteries are good - put new ones in with same problem. Took out memory card & turned on camera - still flickers.
  • aka_db Dec 31, 2007
    hi i also have this problem. When using the LCD to view what you are planning to take a picture of, the display flickers and shows incorrect colours and lighting. this is especially bad when in lower light scenarios. When the image is taken, they show up on the LCD perfectly (as do the menu's etc..)and they save and transfer ok to the computer. I logged a call with Canon support, they advised to try removing and replacing batteries and memory card, if this didn't fix it (which it didn't), then it needs to go to a Canon repairer, but no mention of the solution you suggested. I might get in touch with them and quote your reference.
    thanks, Daryl.
  • Canon Master
  • 4,738 Answers
This could be early signs of imminent failure of a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 28, 2007
Samsung flickering fix
try this option reset settings to factory default
reconnect lcd cable from mainboard to lcd panel
Sep 05, 2014 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Picture take 3-4 minutes before it comes on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 24, 2017 | Maxent Mx-42x3 42-inch Flat Panel Plasma...
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
I ahve a Yamaha v667 amp and run my PS3 though it. When i have the setting at 1080p the screen flickers green. When i turn off 10809 it works fine. If i run my PS3 straight to my TV the flicker goes away?...
The problem must be with the Amp's video processor. Did you try using both the HDMI cables one by one directly form the PS3 to the TV and confirm if its not a cable problem.
Next try switching the PS3 video output to 720p or 1080i. if the picture is ok your Yamaha is have having problems processing Full HD signals.Was it OK before or you are trying this out for the first time. More on reply.
Jun 02, 2011 | Yamaha RXV667 Receiver
The screen just keeps flickering u can see the words but picture just keep flickering
the video goes though the PIP module, and there are a couple of surface mounted electrolytic caps that need to be changed, and that will take care of your problem.
Nov 30, 2010 | Mitsubishi WD-62725 62" Rear Projection...
The screen is not turning on even though the rest of the laptop is working. how do i fix this?
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 16, 2009 | Compaq Computers & Internet
Loose hinge,no picture but sounds otherwise OK
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 02, 2009 | Computers & Internet
Turning on TV after power outage
Not sure what you mean by "older", but I assume it's a CRT display. It takes some time for a picture tube to come up from a completely cold start. It has to get all of those electrons hot enough to start flying around, and also build up a high voltage on the screen. You don't notice it in normal operation because the power button doesn't really turn everything off, but just puts the set in standby mode. Unplugging, though, lets everything cool off completely.
If you're talking real antiques, with tube-type amplifiers, then the warmup time could be even longer. I remember as a kid watching the blank screen for a couple of minutes before a picture appeared.
What you describe sounds like normal behavior for a CRT television. Not sure what's up with that flickering red light, though.
Jun 26, 2008 | Televison & Video
Canon PowerShot A85 Digital Camera Logo
601 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
