Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 52" projection tv...d52w20
The convergence recently went out on my tv and was getting it fixed tommarow when this evening the screen went completely red and then the tv turned off by itself, now when I turn it on the screen is all red and then turns off completly, could this be related to the convergence issue or is it a completely new issue?
  • 373 Answers
You could have a bad red tube or the socket on the tube may be bad; completely different from convergence
Posted on Dec 30, 2007
I own a RCA d52w20 and the convergence is terribly bad. I set it up, used auto convergence and even went to the service menu for the 25 point setup. But my screen is still terribly bowed and i cannot find...
Try this with TV off Press and Hold CH- VOL- at same Time Hold untill TV comes on.
Then you should be in Factory setting menu, it will either corect the Problem its self or go straight to Service Menu for Techicians.
Feb 24, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My screen image is concave, like a funhouse mirror. The image is distorted at the top and bottom of the screen. Any suggestions?
it is called pincushion circuit. either the diode went bad, the capacitors, or just maybe a simple solderond the bad connections.
Nov 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence off line
How did you fix it?????? I though I tried everything!
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence off on Digital Cable
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
Jul 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV 52 Inch
If its only one color its the Convergence amp board that needs replacement. If its more than one color you cant control you need the Convergence power supply board. If you need parts for your model let me know and I will post a link.
Jun 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converges problem for my RCA 52
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
344 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
