Question about Mitsubishi WS-55511 55" Rear Projection Television
Vertical green line on left side of screen rear projection tv
On sunday Dec 23 we had a power flucuation and today when I turned on my tv a vertical green line on left side of screen appeared.
it is a Mitsubishi 55 inch model WS55511
  • 2 more comments
  • Twmackey Dec 28, 2007
    where would I find the fuses
    Please send the instructions
    Tom
  • Twmackey Dec 29, 2007
    twmackey@aol.com
  • Twmackey Jan 05, 2008
    It was the convergence that failed, the technitian said that when he took it apart the capitors all fell out because of the heat. The cost was $488.00 to get it fixed. The picture hasn't been better. He said the epoxy that hel them in was not good on the earlier sets but the new generation epoxy should be better. I thought they were solder in. The second thing is there is no fan in the rear of the tv to disapate the heat. My brother has 42 inch Rear Projection and his has a fan on a thermastat that game as factory built in. Would a fan be advantagious?
  • 1,113 Answers
It may be the beginning of convergence failure. IF so, it will eventually fail totally and you will be faced with a $400 repair.
But, could be something less severe. I cannot guess precisely because there are many possibilities and only way to tell would be taking voltage and other measurements in search thereof.
It could, for example, be the convergence lines crosstalking into the video signal. Transistor switch somewhere in the system may need changing. It would require testing to find out.
If you do have an extended warranty policy it should be covered under that, so check that angle out before the police expires.
It will be a convergence issue, probally needs green convergence board repaired/replaced
Posted on Dec 28, 2007
  • Soulvisitor
    Soulvisitor Jan 06, 2008
    Fan couldn't hurt, they are soldered in as well as epoxy due to hi temps being reached on components, thanks for rating me not. but I was right "It will be a convergence issue"
    Guru:
  • 1,894 Answers
Fuses may have blown out i think..
  • 4 more comments
  • dewan nafees ahmed Dec 28, 2007
    ignore my previous post please..
    If you are handy, and can solder, you may be able to save about 700
    bucks if not more. There is a very common problem with these Mitsubishi
    TV sets. There is a digital board inside these puppies called the DM
    board. A lot of times there are four capacitors that go bad inside of
    these TV sets. Sometimes, depending on how bad the capacitors are, and
    if the capacitors did not blow out anything else on the Dm board, you
    can simply replace these four capacitors and this will fix your TV set.
    The average that this works on is about 65 to 70 % of the sets can be
    repaired with this fix. The others are power supply issues or the DM
    board has other issues. If you would like to attempt to repair your TV
    set, you will have to do at your own risk
    If you would like to attempt to repair your TV set, I will send you the
    instructions on how to do so. If you do not know how to solder well,
    do not attempt to replace the capacitors yourself. Pay a pro to do this
    for you. After all you are already saving a bundle of cash. Leave an
    e-mail address, and I will forward you the fix with and without the
    light engine. And if the capacitors inside the board are not swollen on
    the tops, as the direction shows you what they look like, change the
    capcitors anyway. I have had a few that looked good but the capacitors
    were on their way out. Good Luck
    Look around on the boards for capacitors that look like the tops are
    swollen, or they may have a black goo coming out of the bottom of them.
    If you cannot see anything obvious, I'm afraid it will most likely be a
    repair for the service center. Good Luck
    i have detailed manual that wil be highly useful for you to solve the problem by yourself.
    if u need it i shall forward it to your mail ID.
    reply soon
    ya i can send it only if u give me your mail ID??
    u dint mention it sir..
  • dewan nafees ahmed Dec 31, 2007
    instructions sent long back. but no feedback?
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green vertical lines in bottom left corner
IN THE MENU USE THE CONVERSION OPTION IF IT HAS IT
Apr 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Green vertical line on the left side of TV
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Dec 28, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 15, 2006 | Hitachi 42V710 42" Rear Projection HDTV
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
