Question about ASUS P5NSLI (0610839134670) Motherboard
Trobble booting i an assembling a new computer. It booted for about 20 sec then shut down now it will not boot. I am running a asus pn5sli mobo, itel core 2 duo @ 2.4, 8800 gt vid card, 2 gigs of 800 ram, and a 450 power supply
  • 26 Answers
My guess is that your cpu or other major component fried. the same thing happened to me. check for proper connections, thermal grease properly applied, ect. there are many many problems that cause this however. try listening for beeps and matching them on a "beep chart". you can find them on the internet. good luck and hopefully this helps. im assuming you recently obtained the parts, so if any parts are broken you can simply return/exchange. nice build btw.
Posted on Dec 28, 2007
How can i boot or reformat using usb in motherboard p4pe-x, or can i boot from usb from that mobo instead? If so, how? I see on boot setup the removable devices, under that after i click removable...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 27, 2011 | ASUS P4PE-X (90-M8LAW1-G0EAY) Motherboard
I have an asus pn5sli mobo with 8 gig ram, nvidia 9800gt gpu,running windows 7 and am having crash issues.can you update bios using a usb as I have no 1.44 floppy installed and can you increase ram voltage...
Hello download your files here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5NSLI/#download
Download asus update in the utility for 64 bit system
Next download the latest bios
Please unzip the files before you install.
Install asus update and select update bios from file.
This can be done while the system is running.
Select the bios file you have downloaded
and the program does the rest.
Remember to download the right bios.Flashing the bios with a wrong file will damage the mainboard !!!!!!!!!!!!
And you need to set up bios when the job is done (the boot sequence)
Good luck
Dec 17, 2010 | ASUS P5NSLI (0610839134670) Motherboard
I bought a brand new M4A785-M, I have all compatable parts, even swapped every piece out onto my comp with the same board and boots fine. The comp booted fine before, I swapped the single core Sempron (1.8...
Is your phenom Phenom-X3-8450e or AMD-Phenom-X3-8450 ?
8450e is suported by that mobo but in the asus suport page you wont find 8450.
Check here https://www.asus.com/Motherboards/M4A785M/HelpDesk_CPU/
8450e runs on 65w and 8450 runs on 95w.
Does your mobo run with your old CPU?
Apr 09, 2017 | ASUS M4A785M Motherboard
I have a pc w/ asus k8v-mx mobo, the problem is it
scan for virus, if it is not a virus change the power supply unit.
Aug 14, 2009 | ASUS K8V-MX Motherboard
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
Boots up for ~15 sec. then shuts down
Usually a motherboard will shut the system down to save itself. So check that the fans are spinning and that the heatsink is properly seated. You should also test in a minimum configuration be removing all add in cards, disconnecting all drives and unnecessary cables, and removing all but one memory module. If this doesn't point out the faulty components then either the motherboard (most likely) or CPU (less likely) is faulty.
Oct 15, 2008 | ASUS P5PE-VM Motherboard
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
ASUS P5NSLI (0610839134670) Motherboard Logo
95 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
