RCA Spirit Of St. Louis Radio/Cassette/CD Boombox
Problem for RCA Spirit Of St. Louis Radio/Cassette/CD Boombox
I own a WELLTECH (juke-box-style)10 CD Tuner HIFI
By richard562 on Oct 16, 2009
I own a WELLTECH (juke-box-style)10 CD Tuner HIFI System bought at one of the LIDL stores in Spain. The rear of the main box indicates MICRO CD SYSTEM/40100/MACDW30 and its front reads "COMPACT DISC DIGITAL AUDIO" and "PLAYS MP3/CD/CD-R/CD-RW". This excellent equipment has suddenly stopped reacting to the remote and will no longer play the loaded CDs or DVDs. When I press PLAY, the screen displays: "READING" and then the system skips from CD to CD - always either displaying
"READING" or "DISC 1" ... 2, 3, etc. but dosn't produce any sound at all. Before strting to display "READING", etc. it displayed "TRAY ERR" but now, since I took out the initially loaded CDs and replaced them with another selection, it no longer does so.
Any ideas on how I might resolve theis problem?
Thanks in advance for any help you can provide.
Solution #1
posted on Oct 16, 2009
Not Rated)
ginko
Rank: Guru  RCA Expert
Rating: 89%, 5079 votes
Hi.
LIDL electronics are usually purchased in big stocks and then re-tagged in Europe or in US, it will be impossible to find schematics.
however from your description I can tell you already that the problem is restricted to the optical drive. The fault is either lens , controller, or motor. Most likely the lens.
When lens pickup is dirty or defective the unit will spin the disk, but the drive will not be able to focus to the TOC on CD/DVD, and will skip to next disk.
To understand if it is the lens , all you need to do is observing if the disk is spinning. A test may be done jumpwiring and energizing directly the spindle motor.
If the spindle motor is working, then it is the lens, otherwise the motor.
If it is the lens, before replacing the lens you can try cleaning it with isopropyl alcohol and water (about 70% solution).
The controller board can also cause problems, but if the unit is operating this is rather uncommon.
I will restrict the diagnosis to lens or spindle motor.
Parts for no brand electronics are difficult to find, however both lens and spindle motor are quite standard parts.
The parts can be purchased at an electronic spare retailer, or if the part number is printed on motor, use part number to get motor specs on google and buy same part.
The lens pickups are almost all compatible on this kind of unit if you take one from a similar unit. Lens replacement is quite a delicate job, and there is a good chance of unsuccess because of lens alignment issues.
Popular Solutions for RCA Spirit Of St. Louis
Questions and Unsolved Problems for RCA Spirit Of St. Louis
Do you recommend RCA Spirit Of St. Louis Radio/Cassette/CD Boombox?
Answer
Answer
I have an RCA Spirit of St. Louis Radio/Cassette/CD Boombox. The CD player has stopped working. How... (More)
Answer
I have a model 543.367 Gershwin and lost my instructions. How do I set the clock? Thank You
Answer
my record player does not work because the belt has slipped off of the pulleys and i dont know how... (More)
Answer
the feed wheel or gear s missing for the cassette player rendering this unworkable is this fixable
Answer
i have a spirit of st louis boombox cd player isn't working i used a general adapter becaue i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA Spirit Of St. Louis...:
Top Boombox Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Boombox Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
