Question about HP PSC 2175 All-In-One InkJet Printer
  • 2 more comments
  • Lillouie Dec 31, 2007
    Computer does not recognize the scanner.
  • Anonymous Jan 07, 2008
    it says scan to email hp photosmart gallery workpad or paint???? then says scanning but doesnt do anything. print works ...
  • kima7 Feb 07, 2008
    when the printer comes on, its fine until it gets to the scanner, then it makes an auful sound and then shuts off . help
  • maverick10 Apr 11, 2008
    the actual printing works fine but when i try to scan anything it just sits and does nothing for a few minutes and then shuts off... does anyone know what the problem may be? please help!
  • 43 Answers
You have to service the scaner craddle if U want to, or replace it with a new part.
The noise is because the scaner cannot align. Under the front panel - under the glass is a white strip that should be read by the scaner in order to calibrate (find the right limit).
If there is some dust on the craddle mirrors or if the CCD sensor is fault, then the craddle wants to go beyond the right limit of the chasis - then the noise apears.
The mirrors and the lens should be cleaned, then if this noise is still there, you should replace the craddle.
In Romania there is no service part available for this printer, there is only the Unit Exchange solution. Very expensive.
Lillouie - If U have reinstalled the AIO with a new driver, you should have a list of scaners that you can select. 2 mabye.
Try from a Word doc to insert picture from scaner/camera and U'll see that there are more than one scaner in that scrolling list.
If this isn't so. Uninstall the hole printing solution from HP, then install it from clean..
Best regards, Sebi
Posted on Mar 19, 2008
Why my printer can scan but cannot print and photostat?
If photocopy and scan working only print not working then reinstall the printer driver .If only scan working then check toner level sensor and finally logic pcb.
Nov 04, 2014 | Office Equipment & Supplies
I have trouble scanning , i press scan and it prints
If the scanning operation was working before.
Turn the printer off and then back on, this will reset the printer.
The scanning opeation will
To use the scanning operation your computer must be turn on and
the printer usb cable must be connected to the computer.
Oct 13, 2011 | Canon PIXMA MP190 All-In-One InkJet...
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan a document to my comp - I have absolutely no idea... I have tried turning it on then pressing scan - doesn't work. Tried pressing Scan when printer off - doesn't work. Tried finding the...
If will need to install the software that came with the printer. If you already did that, you can start HP directory by clicking the HP icon on the right hand side of the task bar. Then click "Scan document" or "Scan Picture" depending on what you need to scan. If you select "save to disk" option, the program will ask you where to save the file.
Oct 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C4180 scanner
Unfortunately Vista has problems with many printers. (Or maybe I should say many printers have trouble with Vista.)
HP has a work around that allows you to scan without using the Scan button. Go to:
C4180 Scan Work Around
They give you 2 options to scan using programs on your system
Thanks for using Fixya.
Aug 28, 2009 | HP PhotoSmart C4180 All-in-One Color...
Won't scan. Copies and prints. But the scan button does nothing.
Did you try scanning from your pc? I never use the printer scan button. Most scan buttons won't work without the "print center" program open as the scan always goes to the pc. I mostly use the windows scan program in the control panel. Try this.
Jul 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
If you go to
Do a search on your printer.
Look for an option for drivers and downloads.
Select your printer and windows vista.
You need to find the print, scan, fax drivers. Not just the printer drivers.
The driver download would be like 800 MegaBytes instead of like 2 or 3 MegaBytes.
Jun 11, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark x6170 will not scan
Try resetting you machines by turning off and unplug, reverse steps and try again. If no go, repost and we will try again. Cheers lilacgerry xxx
Jan 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
115 people viewed this question
Ben Johnson
