Question about Linksys Wireless-G Game Adapter [ WGA54G ] (108451)
Wireless G Game adapter
Wireless game adapter installed. When we test media the adapter shows as wireless bridge. Wireless Network will say connected, but when it passes on to the IP address, it goes back to wireless network and says not connected.
    Sergeant:
    Champion:
  • 427 Answers
Make sure that it is assigning a subnet mask and a default gateway.
Posted on Mar 23, 2008
The wireless router wont connect to the xbx adapter
is it a new wireless adapter? if it is..
in order for the xbox works wireless
you need to have a wireless network adapter from xbox
if you do have the wireless network adapter if it black it has a installation disc that comes with the packet
install the disc make sure that the wirless network adapter is unplugged before you inserted the disc you will prompted an update select yes for the update once it is done installing remove the disc and turn off the console and plugged in the wireless network adapter then press the guide button the silver button in the middle of the controller and go to settings blade and choose system settings,select network settings,then configure network it must have the option for "wireless mode" select this option and select scan for network,choose your network if it ask for WEP,WPA /WPA2 this is the passcode that you set for the wireless network.after you enter the WEP,WPA/WPA2 you are connected
if it is the white adapter all you need to do is pluggin the wireless network adapter while the console is turn off once you switch on the console test the connection and you will be prompted to update select yes for the update then press the guide button the silver button in the middle of the controller and go to settings blade and choose system settings,select network settings,then configure network it must have the option for "wireless mode" select this option and select scan for network,choose your network if it ask for WEP,WPA /WPA2 this is the passcode that you set for the wireless network.after you enter the WEP,WPA/WPA2 you are connected enjoy the game =D
May 29, 2010 | Microsoft Xbox 360 Console
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
How to hookup wireless internet
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 07, 2010 | Video Game Consoles & Games
Xbox 360 wireless adapter connects but can't join parties!
If you think its the wireless adapter, try using a laptop (that has wireless) to connect your xbox to your network. Just get a straight through (network) cable connect one end to the xbox and the other into the ethernet port on your laptop. Then go into your network settings and bridge the connections (if you don't know how to bridge connections try youtube or just google it) Now your laptop acts like your wireless network adapter. See if your problem occurs with the laptop, if not then it is the adapter. I hope this helped solve your problem.
Jun 22, 2009 | Microsoft Xbox 360 Console
Xbox live wireless network failure
did you go into your computer settings? i think you have to take your firewall off maybe. im not totally sure on this one. good luck though! if you call microsoft they might have better answers sorry!
Dec 27, 2008 | Microsoft Xbox 360 Console
Wireless network always fails for xbox live.. i need help
go to settings and conection settings and put your connection setings in
Dec 26, 2008 | Microsoft Xbox 360 Console
Can you help me please??
you need to setup a network bridge between the tower pc and the xbox 360
Select Control Panel/Network Connections and while hovering over Network Connections, right click and choose Open. This will open a panel that should list your network connections.
This image shows all my existing network connections. Yours may not have the same adapters. The two adapters that matter are your wireless adapter and your Ethernet adapter. They will have different names than mine because I have renamed them from their default values. I have highlighted the two adapters in the graphic below.
Step 2 If you have both Ethernet and wireless adapters (and you must in order for this to work), then both of them will be listed in the Network Connections panel. Using the ctrl-click selection method or the drag-area method, select both adapters.
Step 3 Right-click one of the adapters and select the Bridge Connections option.
Step 4 You will see a notification that the bridge is being built. This may take a few moments.
Step 5 Once the bridge is complete, you will see the bridge icon and the network adapters as shown below:
Step 6 The bridge is only partially complete at this point. To complete the configuration, you need to relate the network adapters to the bridge. I’m not exactly sure why this is because you have to select the adapters to create the bridge in the first place. This is my first bridge, so it’s possible there is a better way of doing it. But this process has worked for me. If you know of a more concise way of configuring the bridge, let me know and I’ll update the process.
In any case, select the bridge, right-click and select Properties:
Step 7 In the Properties dialog, put check marks in the network adapters that you want to bridge. Make sure you select the wireless and Ethernet adapters.
Step 8 Now, the bridge is complete. It will take a few moments for your laptop to finish the configuration, get a new DHCP lease and complete the connections.
To verify if your bridge works, connect the XBox 360 to your laptop’s Ethernet port and connect with XBox Live.
Dec 10, 2008 | Microsoft Xbox 360 Console
3 XBOXES PC AND LAPTOP CONNECT TO ROUTER WIRELESS
If you're looking for an option to connect the XBOX consoles to your wireless G network you'll need to purchage a wireless game adapter (simular to a wireless bridge) like this one for linksys http://www.newegg.com/Product/Product.aspx?Item=N82E16873999102 for each console you wish to connect. You will have to connect the game adapter to your pc first to configure it on the network and then connect it to the XBOX. Xbox should detect the wireless adapter and you should be ready to go.
Feb 20, 2008 | Computers & Internet
NetComm NP285 xbox compatibility?
when I go to network settings-->advanced--> wireless, it tells me that the wireless adapter was not detected.
Where are you getting this message from?
Dec 05, 2007 | Microsoft Xbox Console
Linksys Wireless-G Game Adapter [ WGA54G ] (108451) Logo
165 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
