Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
LaCie Mobile 500gb not working
My external HD fell from my bed and now it's not working. When I start it, there is some noise (vibration) but it stops after few seconds. The drive doesn not show on my Macbook. How can I retrieve the files??
  • Karin Nicolas
    Karin Nicolas Jan 17, 2008
    Have a similar problem [with a 60Gb Lacie Porsche] than has fall from table. Not so hard! it beeps (two diferent tones of beep alternating) when plugged to power and the computers says "no - readable disk" when plugged to usb. Help wanted. THANKS
  • 1,006 Answers
Just buy new external ( HDD ini is fine) just change the external for both off you
Posted on Jan 27, 2008
  • dj_brown_123
    dj_brown_123 Jan 24, 2012
    Explain in common English, can the information on the humming hard drive be taken off? Im having this problem as well
Lacie by stark external hard drive is suddenly not recognised by my computer (always worked until now) and has a permanent red light. Tried all usb ports and restarting computer. Whats wrong?
have you dropped it? it could be any number of disc errors, two of the most common errors are caused by viruses and dropping. try putting the hard drive in the freezer for a day or so in a moisture and static resistant bag. just a possibly remedy, if that doesn't work, try removing the casing on the hd and setting it as a secondary drive after you plug it inside a desktop computer.
May 09, 2011 | LaCie 500GB Starck Mobile USB 3.0 External...
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have a Lacie 500gb
Clicking noise is indicative of hardware failure. You could of course try a different computer, but chances are it's a goner. With hardware failure, the only way I know of rescuing data, is sending it to a data rescue company. Expensive. Which is why you need a minimum of two copies of everything you plan to keep..
Jun 10, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computer doesn't recognize my Lacie HD
From your description it sounds like you power adapter did indeed fail at first, but if the HDD spins now the adapter seems to be working fine at the moment. If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Dec 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie hard drive 500gb
THE CARD CONNECTED TO HD MAY BE NOT FUNCTIONING OR THE HD MAY BE HAVING PROBLEM OR CONNECT PROPERLY THE HD CARD
Oct 22, 2008 | Audio Players & Recorders
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
337 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
