Question about Sony Xplod XM-1652Z Car Audio Amplifier
Amp connection id like to connect the high level input of my xm-1652z from a speaker out terminal of another amplifier,the RMS power of the other amplifier that id like to connect is 140 watts x 2,maximum power is 240 watts x 2,. i want to be sure if the voltage content of its signal or the whole signal itself is okey or proper and could not damage the xm-1652z?
  • 631 Answers
The speaker level input is designed to accept the speaker level signal from a head unit. This is generally no more than 20 watts RMS. If you drive the inputs with more than 20 watts, you risk damaging the input circuits of the amp.
Posted on Dec 28, 2007
Can i bridge a Sony Xm-1652Z 2 Channel amp to 2 subs it gives me 2ohms
No - it is not 2 ohm mono stable
  • 1000W max power
  • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
  • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
  • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
  • OTL (Output Transformerless) circuit
  • Pulse power supply
  • Line & High Level Inputs
  • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
  • 80 Hz, -18dB/octave Low Pass Filter Switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
What speaker componets do need to buy?
  • 1000W max power
And i would say that the best use of this amplifier would be for sub-woofers.
Feb 19, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
How do i bridge 3 subs to a 4 channel amp
My information shows the XM-1652Z as being a 2-channel amp. It will not be stable below 4-ohms in bridged mode. For best power, your subs will need to be 2-ohms with all 3 wired in series. This will present a 6-ohm load to the amp. After wiring the subs in series, connect the positive speaker wire to one channel (+) and the negative speaker wire to the other channel (-). For the 1652Z no other wiring is necessary. For subs you will also want to set the LPF (80Hz) switch to the "ON" position (to the right).
Keep in mind that the rated output is only 400 watts RMS at 4-ohms in bridged mode. That's kinda wimpy for 3 subs. You would probably obtain better results from two 2-ohm subs, each connected to a separate channel. That way each sub would be getting 200 watts RMS, still low but there's lots of good subs that will sound pretty loud with 150-200 watts
Mar 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I have a Panasonic twin subwoofer system. 7000w PMPO, 600w Rms multi amp system. With 2 main speakers, 2 woofers and 2 surrond speakers. The system is not working but the speakers are working properly.Is...
Yes it would be possible, acquire a home receiver or amplifier with either a crossover or an equalizer to filter out the high signals for the subs and is should work fine. Of course if the impedance does not match you do not want to blast the sound through them.
Mar 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp model 1652z
1000W max power
<b>
</b>
Pulse power supply
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Trouble shooting XM-1652Z Amp
Grab yourself a test light and make sure that not only the 12v red power wire is putting out power but the thin blue or 12 volt turn on wire is also showing power. Then test the ground terminal and make sure u have a good ground. If that doesnt work try checking the amps fuses and check the fuse and connection on the battery. If everything checks out ok and the problem persists then put a small test speaker to the channel outputs and make sure that u are getting noise from those channels if you dont get any noise then u most likely have bad outputs and blown channels, you will need a new amp. Good luck, hope i was good help.
Jan 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Wireing
I believe that this model Sony amp includes High Level inputs. Those allow you to connect the normal speaker wires coming out of the factory stereo to the amp. If for some reason it doesn't include the inputs you can buy a high level to low lever converter that will give you rca from the factory unit.
May 06, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
155 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
