Is there a reset button on the A640. My camera suddenly started displayine a lens error when I turn it on - I cannot turn it on in any mode. I know that I can send it to Canon, but I was wondering if there was a simple fix - ie - reset?
- Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A640 Digital
the screen on my canon a640 has started to turn blue around the edges, what's the problem and how...
(More)
the screen on my canon a640 has started to turn blue around the edges, what's the problem and how much does it cost to fix
When I press the left button (on the 4 way directional dial on the right) in shooting mode, my...
(More)
When I press the left button (on the 4 way directional dial on the right) in shooting mode, my camera switches off, and the lens doesn't even retract back. The same thing happens when I'm reviewing my pictures.
i have a canon a640 and recently got a new computer. i lost the original setup disk that came with...
(More)
i have a canon a640 and recently got a new computer. i lost the original setup disk that came with camera. trying to up recent pictures to my computer (windows xp) but i do not read the camera. is there any location where i can download software to install camera on new computer without disk?
powershot a640 is beeping about 5 or 6 times, says on the screen lense error plese reset. whats...
(More)
POWERSHOT A640 IS BEEPING ABOUT 5 OR 6 TIMES, SAYS ON THE SCREEN LENSE ERROR PLESE RESET. WHATS WRONG? ALSO IT LOOKS LIKE THE LENS IS JAMMMED HELP!
the front lens cover of the camera is loose and falls in front of the lens... I think I know the...
(More)
the front lens cover of the camera is loose and falls in front of the lens... I think I know the answer but would this need professional fixing? Also no matter how full batteries there appears to be no power and no corrosion inside it.
