Question about Mitsubishi WS-55511 55" Rear Projection Television
Green vertical line on the left side of TV
Recently we had a power flucuation on sunday and today I noticed a green vetical line on my Mitsubishi ws55511 TV.
    President:
  • 4,402 Answers
Know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
Info on the reason the tv does not turn on with the main power button or the remont control unit. after many attempts the tv starts to turnon shows a green picture with horizontal lines and is cut off...
Your vetical ouput deflection is gone that's why it will not power up. This is commonly caused of shorted vertical output IC. This is not DIY because the FF is still to be consider :
1. Fusible resistor in line with the supply of vertical output IC.
2. Yoke winding might be open.
3. No vertical output from the jungle IC.
I've advice you to send it to the nearest Sony service center in your area.
Hope it may help you.
Have a nice day.
Feb 08, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Green vertical lines in bottom left corner
IN THE MENU USE THE CONVERSION OPTION IF IT HAS IT
Apr 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
I have a small green vetical line in my sony bravia xbr 52"
Unplug the TV , the hard reboot will cause the line to disappear in a few minutes, must be some algorithm that kicks in
Feb 21, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Mitsubishi WS-55511 55" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
