Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
I am having issues with my DLP that is only 2.5 yrs old. I have taken a video of the problems at the two links below. I have two problems, one there are vertical lines going across the tv from top to bottom on all the channels, its worse on the HD channels. On the second problem there are blue snow like specs happening on all the channels. A third problem that is happening in the last two days (that I do not have a video) is that the TV is like flipping the picture. So the bottom of the picture ends up at the top of the picture at moments.
http://video.google.com/videoplay?docid=-8930381261840211648&hl=en
http://video.google.com/videoplay?docid=1405120884414905992&hl=en
I had a repair guy come out and tell me I need a new light/projection? engine, and it would cost $950 for the repair ($700 for the part). He was not a Mitsubishi certified dude though so I dont know if I trust it.
Any ideas?
Thanks,
    Problem Solver:
  • 23 Answers
I have same blue line problem but only on inputs and analog channels by using internal tuner the HD channels are perfect! best picture ever all my other inputs produce Blue lines
Posted on Mar 05, 2010
    President:
  • 4,402 Answers
Sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Posted on Jan 07, 2008
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
My mitsubishi diamond series wd-62825 picture is too dark
There is something I remember and it may be the model you have---Mitsubishi can tell you or you can look for yourself----a few models made at about the time this set was made had 2 mirrors----one a tiny one that faces up and reflects the picture into the large rear mirror.
Dumb idea--the little mirror gets coated with dust and brightness drops up to 70%---
The safe and correct way to know is to remove the entire front screen with its frame---both mirrors (if yours has 2) will be easy to see.
The large mirror hangs at a angle and down so it never gets dirty--don't even think of touching it or using glass cleaner on it--any mark on it will show in the picture.
let me know if you want to remove screen unit to see if one mirror or two---a call to mitsubishi would answer that.
May 15, 2012 | Mitsubishi WD-62825 62" Rear Projection...
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Horizontial lines and picture deteroration
This one is tough. Can be either the DM module, formatter board or optics block assy. Check for bad capacitors first in DM module, then signal board then formatter board. If your lucky, bad capacitors maybe what it is. If not, a new optics block is what you'll be needing.
Dec 20, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
I have the same problem with my tv, my tv tech said mitsubishi knows of the problem and knows how to fix it, but it would cost me 700.00 plus his labor to take out the chassis and send it in to mitsubishi, plus I would be without a tv for up to a month. this is b.s.
Oct 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Picture noise blue/pink
do self test diagnosis here in threads or goto ctechnicians.com
Nov 03, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-52525 DLP HDTV screen went bad
i have the same tv i got it for free from my work it was a return there's no picture or sound but the green light blinks on the timer light i took it to a tv repair place ive researched the problem alot most forums said it would be the dm module or the capacitors on it but this guy is sayn its not that and its not the lamp but it could be the color wheel or some balance thing he was bein an a hole about it i paid for a diagnostic and he said hes not gonna look at anymore cuz i dont sound interested in payn what he says MIGHT be the problem and i dont want to get screwed for a bunch of money any tips??? thank you
Aug 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
236 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
