Question about Reddy Heater-30-55,000 BTU Variable
35000 reddy kerosene heater
I bought it used itworked great for years but this year intial start up it worked fine. i filled it up and will not stay running. if i clean the nozzle blow out the lines it will run for ten seconds and shut down i am unable to find like trobleshooting on this one
  • beaus cars Dec 28, 2007
    serial number for this unit is 28725
  • Bill Range
    Bill Range Dec 14, 2008
    I have the 60K kerosene heater, it run for about 5 min. and shuts off. I use it in my woodshop for about 5 years, might need cleaning, but don't know how. Can anyone help.
    Problem Solver:
  • 8 Answers
There is an air pump on the back of the fan motor. The plastic cover is probably cracked, allowing the air pressure to escape. This pump causes the nozzle to siphon fuel from the tank and MUST privide the rated pressure indicated on the data plate of the heater. Spray soapy water on this cover to check for leaks while the motor is running. You will need to remove the end and top covers to do this. If leaking, it may need to be tightened a bit, or if cracked you will need to replace the cover. Set pressure when replacing the cap with a low pressure gage.
Posted on Jan 18, 2011
    Problem Solver:
  • 5 Answers
My unit is a kerosene 35000 btu unit...just had similar issue.
It is very possible that the spark plug is
  1. fouled out (dirty)
  2. mis-gapped
take the top cover off, you will see the plug. There is a sheetmetal plate held on by two screws holding the ground, plug, and nozzle together. It is easier to just remove the plate (you will have problems with the plug nut if you don't).
remove the plug with a plug socket, probably 5/8.
I used brake parts cleaner to spray off the electrode of the plug then a wire brush to clean it.
check your plug gap...this might be crucial. my gap was specified on a label stuck on the inside of the bottom of the body. The plug on my unit was way too small. Adjust gap if necessary using feeler guages.
reinstall parts and plate. (I actually tack-welded the plug nut into place for ease of maintenance later). Note that the electrode needs to be a specific angle, relative to nozzle....probably diagrammed on the same label as the gap spec.
replace top and see if she'll fire up.
...last note...also might check your fuel pickup/filter. It is located behind the side panel in the unit
good luck...hope I have helped you
Posted on Jan 11, 2009
  • 625 Answers
Go to this site www dot desatech dot com. on the main page there are troubleshooting items. navigate to this part and find your problem and "fix"
Posted on Dec 29, 2007
Have fuel but no spark at the spark plug 35000 btu
The electrodes might need cleaned. I am attaching a link, please check out the FAQ section, then scroll down and click on FAQ for spark plug heaters. I hope this helps. Reddy Heater Parts Sales Online Mr Reddy Heater Parts Master Heater Parts...
Jan 21, 2018 | Reddy Heating & Cooling
I have a reddy 55,000 btu kerosene heater i bought used and it worked fine the first day it stayed on as long as i wanted it to now it only runs for like a minute and i don't know why it has plent of...
It could be a pressure problem, old fuel, clogged nozzle, etc. If you can furnish me with the correct model number, I will be able to help you further. Reply by using the Leave a Comment link.
Mar 24, 2011 | Reddy Heater-30-55,000 BTU Variable
Flame won't stay lit
This is a classic reddy heater problem. I have a tip at which should solve your problem.
Thanks for using FixYa and for the great rating.
Sep 22, 2010 | Reddy RLP55V Utility Heater
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Ingition shuts down within 30 seconds. I realize this is the auto shut down, but there is no reason for it to do this. I took the cover off and found it would stay lit and run if I didn't tighten the...
Can be the Photocell {eye} at the back of the burner or the inline fuel filter.Photocells are easy to replace and when you install the new one make sure it's aiming straight to the flame.Inline filter can be cleaned by using forced air,but not recommended.Filters are cheap.If none of that works check the air pressure at the pump,rear of machine,little plastic pipe plug.4 to 5 P.S.I
Dec 23, 2009 | Reddy Heater 60,000 BTU Kerosene...
Kerosene does not get stale or go bad like gas. I would make sure the tank is close to full to prevent condensation and just put it away in a dry place. I have stored over 50 each year for many years and have never had any problems.
Mar 18, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
check your air lines that go to the burner nozzle for any breaks and clean all of the filters.
Dec 22, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
948 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
