There are 4 bolts on the bottom of the machine that hold a craddle that holds the tub in place.You can get to them by tipping the machine up. I hope that is what you mean.
Was this helpful?
Yes
No
Popular Solutions for GE WBSE2090A Top Load Washer
Daughter washed a down pillow. Had feathers in pump, electric panel and around drum. Cleaned pump,...
(More)
Daughter washed a down pillow. Had feathers in pump, electric panel and around drum. Cleaned pump, electric panel and drum area. Motor does not operate, belt appears good and is taught against pulley. Pump is working. Washer ran one time following initial cleaning. Tom in Texas
washer will not spin! Motor just hums. I got it to spin once but it started with clunking sound and...
(More)
washer will not spin! Motor just hums. I got it to spin once but it started with clunking sound and after it was spinning a while ( couple of minutes), it seemed like it shifted to a higher gear and went faster. Have not gotten it to spin again.
washer has water running into it to start a load but it immediately drains out. We just cleaned...
(More)
washer has water running into it to start a load but it immediately drains out. We just cleaned behind it and it was working fine prior. We moved it during the cleaning process. Why won't it fill?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
