Question about Magellan Roadmate 760 GPS Receiver
Map update for the 3250
Is there a map update for the magellan maestro 3250 if so where do I locate the updated map.
thanks in advace,
Kellie P.
  • Anonymous Mar 18, 2014
    magellan maestro 3250 will not sync
I would avoid map updates from Magellan like the plague. They have a strange way of frying the units. Unless you want to be without your GPS and fighting with Magellan for months, leave the map software the way it is.
Posted on Feb 20, 2008
How can I update my Magellan Maestro 3210?
  • Hi if you want to update the firmware just login to the website of Magellan and make sure that the GPS must connected when doing the update.
  • For the map update call the customer hotline and check if you can get a free map update or if they have discounts for map update.
  • If you have followup questions don't hesitate to reply to this solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 15, 2010 | Magellan Maestro 3210 GPS Receiver
How do I update my Magellan 3250
You can go to Magellan's website but I can assure you there are no map updates for free.
Try resetting the unit.
Turn it on and find the tiny hole marked reset - -then push and hold a paperclip in the hole until it resets. Try this 3 times if you want to clear it out and start with the maps it came with.
Go here - the official Magellan website and read until you see the word RESET - this is for your model.
http://www.magellangps.com/support/faqdetail.asp?faqid=480&prodid=1948
Please rate me hi it makes a big difference to me - thanks
Rice
Mar 30, 2010 | Magellan Maestro 3250 GPS
Need Set-up CD Magellan Maestro 3250
let me say this 1st because this will be the easy way to fix this assuming you tried to either run the update or ran it again after the failure. if thats the case.
im going to assume you tried to update your unit to the 4.46 update that you downloaded off the magellan site,HERE ( if you havent, i suggest you do it before continuing) and in doing so it bricked your unit.
Magellan Will repair or replace any of there gps sytems that were rendered inoperative due to their updates. they will check your account to see if you downloaded the update.
  • register your unit on magellangps.com if you havent already
  • download the update
  • attempt to install update on your computer
  • call magellan tell them your unit is not booting up after the update
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
hopefully you understand what im saying here.
should you decide to take a different route, let me know and i will help you get it up and running if possible.
bill
Nov 06, 2009 | Magellan Maestro 3250 GPS
Map is stuck on an old location and won't change to the new location on the map
take the unit outside so that it has a clear view to the open sky, turn the unit on, then push the reset onthe side(you need a paper clip) youll know its reset once you see the magellan logo screen with the black loading bar on the bottom. let in sit outside to Aguire the satellites. this may take upto 30 minutes. if that does not work, you can try the latest update. bill
Jul 14, 2009 | Magellan Maestro 3250 GPS
Touch Screen
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
Feb 07, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3250 Regions Problem My magellan maestro 3250 shows the regions,Canada,Alaska.Hawaii,and Puerto-Rico. How can I change to US?
I had the same problem, magellan would not give me a code for the map to just download but did agree to send me a new unit and then have me send back the old ubit after verifiying my receipt. did have to give them a credit card # to make sure I send back the old gps
Dec 12, 2008 | Magellan Maestro 3250 GPS
Magellan 3250 won't update
Hi, I had the same problem with my 3200. Got the update, and it bricked my unit. After 3 weeks of searching the net for solutions, all of which did not work, I called Magellan Tech Support today. Simply told them that I was updating the maps, update failed, and now the unit will not boot past the blue magellan screen with the progress bar. They asked for some information, including the email address that you used to register the product, and the serial number of the unit, as well as the map update information...which you had to register to get the unlock code. They are able to see all of this c in their tests on the unit, which of course did not work. I was then given a RA#, and account #, and was assured that I would get a pre-paid shipping label via email within 24 hours. All you have to do is pack the unit and take it to fed-ex with the label. They will fix your unit with the updated maps, and return it to you via Fed-Ex. Took no longer than 15 minutes on the phone, which beats the 3 weeks of research that did not help. Problem solved. Just call Tech Support, this is a well-known problem, and they will fix your unit and update the map. Hope this helps.
Dec 06, 2008 | Magellan Maestro 3200 GPS
Need to update the maps on the gps magellan maestro 3225
I need to update the map on my 3225 Magellan Maestro, can anyone help?
Sep 28, 2008 | Magellan Maestro 3225 Car GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
216 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
