Question about Haier HTF27R11 27" TV
Colorful static on tv screen
My TV screen displays colorful static. We receive cable, but the other TV does not have the static on it. Could the TV been damaged by a recent windstorm?
However, if the cable isn't at fault if I might add...your tuner maybe needing attention ie: R.F. section ... check for shorts cable input.
Posted on Jul 04, 2008
  • 107 Answers
Contact your cable provider, and let them know what is going on to your cable..^.^
Posted on Jan 23, 2008
Samsung Model #LN32C540F2D comes on but no picture. screen is white and has colorful lines on the side of the screen.
Is it possible to post a picture of the screen with the colorful lines? You are looking at either a tcon and an lvds cable or a bad display. May be able to narrow it down if I can see a pic.
Mar 21, 2014 | Samsung LN32C540F2D 32 LCD TV
Plasma tv video
Could be the power supply inside the TV is bad. Check with your local authorized Samsung repair center. DON'T try to fix it yourself.
Dec 03, 2013 | PN50C675 Samsung Factory Refurbished...
TOSHIBA 55" INCH .. COLORFUL LINES ON THE SIDE
looks like a problem with the cable or screen. i would call an electrition or get a new tv.
Jul 14, 2013 | Televison & Video
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
Colorful spots on tv when turned on. Have to turn off and on several times to get rid of most of them
Possible static charge on screen, you may have to clean screen with mild soap and water, Damp cloth only! Do not let excess run down the screen! Also check the outlet to be sure there is a ground pin and path on the AC cord..... Carpeting can hold a charge, use a humidifier or spray the carpet with Frebreeze or antistatic spray....
Feb 15, 2010 | Panasonic PT-44LCX65 Television
I have a Sharp Aquos TV that only displays a colorful grid.
your t-con board is failing call a tech to install a new one
Sep 19, 2009 | Sharp LC-60C46U LCD TV
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Colorful "speckles" on screen
Could be the screen burn from watching T.V. on a show and the thing burnt in (in this case the colors, yes it can burn colors.) and there's nothing you can do. The insides of the T.V.'s have plasma gases which can flow out of control.
Jan 14, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Colorful Dots
check the connection of the cable comming from the cable box to your tv either it is not connected proper or the wire that connects it is faulty and needs the be replaced.if that does not work let the repair man check the IF circuit, video amp and the tunner.it they could be causing the static.good luck my friend.
Jun 16, 2007 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Haier HTF27R11 27" TV Logo
150 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
