Question about Olympus Stylus 790SW Digital Camera
Wont turn on
Bought this camera for my son for Xmas. Supposed to be waterproof so he took it surfing. First day no problems, second day turned itself off and won't turn back on. Put battery on to charge, charger keeps blinking but after 5 hours camera will still not turn on. Is this a cemra, battery or charger problem? Any help greatly appreciated. Thanks, Karyn.
  • 1 more comment
  • leoartuza Dec 28, 2007
    After two days of underwater use, I downloaded the pictures to my PC, after that, I verify that the pictures weren't deleted from the XD card. Then I turn off the camera. The next day, I try to use it and it wont turn on again. The charger's red light blinks, but after 5 hours of charging, the camera wont turn on. I also would like to know if it is a camera, batery or charger problem.
  • Tony G Jan 01, 2008
    Think so, with a Olympus 790sw, exactly same scenario. Son is now stranded in Australia without a camera! really hacked off with Olympus if not a simple fix. Will be contacting Olympus to see what the story is but in meantime anyone else out there had a solution offered yet?
  • rafahdr Mar 04, 2009
    I was taking some pctures at the beach, for sure in the water, suposed waterproof. So, first and second day it worked good but the third day I was using when the Lcd got black an then the camera turned off. What can I try to do before live it at authorized service.
Gvgvv
Posted on Apr 02, 2011
I have the olympus stylus 770sw, charger would only blink..... I unplugged the charger (not the wall side, the side on the box where the battery goes) and twisted the cord 180 degrees and plugged it back in. It started charging fine
Posted on Oct 10, 2008
Your all in trouble.. im on my third one..a pro surfer/shaper... you must wast it completly with fresh water immediatly after leaving the sea.. the chrome corrodes within hourd and allows the seals to leak. also sand etc gets stuck in the lense door...
Posted on May 25, 2008
Check the battery compartment for condensation...if thre is condensation inside the battery has probably been short circuited...replace it.
Posted on Apr 21, 2008
I had the same problem. I contacted Olympus and they said one thing to try is to unplug the cable from the charger (from the charger side, not the wall side), twist the cable 180 degrees, plug it back in and try charging the battery.
It sounds weird, but they said it sometimes works.
Posted on Apr 07, 2008
    Problem Solver:
  • 12 Answers
Remove battery from charger. Unplug charger for a minute, then plug back into outlet. Reinsert battery and see if red LED comes on and STAYS on solid. If so, charge for about 5 hours.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/travis_e264b9f3ca4047ae
Posted on Jan 30, 2008
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
My son took the turn signal switch out of a 2001 pontiac aztec and now it won't start is it supposed to do that
well gm does some stupid things to their cars it is a possiability...put it back and see
Aug 23, 2012 | Pontiac Aztek Cars & Trucks
I purchased a discovery kids digital camera for my g.son for xmas.it is supposed to store 120 photos memory is full at 29.can u help?
camera can capture up to 120 still photos (640 x 480), even full-motion AVI video clips make sure the camera is set to the 640 x 480 resolution to have the 120 still photo capabilities. if set for higher resolution will not hold as many
Jan 11, 2011 | Toys
Its a waterproof and shockproof camera. I tried taking pictures underwater for the first time. Today i took a couple pictures with the camera and later on, I turned on the camera but is a black screen I...
Well, your first problem is that the phone is not completly waterproof. (as in taking it for a swim) Many consumers have complained about this phone not actually being waterproof. I would get myself to the wireless store and complain pronto!!!!
Mar 29, 2010 | Sony Ericsson K850i Mobile Phone
Pentex Optio W30 turns on but black screen for 5 secs & turns off
Try a new battery first, much less costly.
A fairly common problem with "underwater" cameras is that the sealing surfaces that are supposed to keep the water out fail to some degree due mostly to lack of cleanliness when the camera is closed up. It takes VERY LITTLE salt water inside a delicate electronic device to wreak all sorts of havoc.
Look carefully inside the camera for any sign of salt deposits or corrosion. If you see that, the camera is likely toast or at least in need of a repair job that likely will cost more than a newer camera.
Dec 23, 2008 | Pentax Optio 30 Digital Camera
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Fisher Price Kid Tough Digital Camera Memory Problem
Hi Jill
I've had an unrelated problem with my son's camera - his flash wasn't working, but I managed to find the manual for the camera at: http://service.mattel.com/instruction_sheets/L8341pr-0921.pdf
Might be worth you taking a look at.
Cheers
Marcus
Feb 18, 2008 | Cameras
Bottom touch screen blurry
it happens if there is moist or dust or sand inside the ds so breath INWARDS through the L or R buttons but dont pull too hard but **** as much as you can until it becomes alright plus keep doing it ... it took me 10 mins to get it right
Jan 05, 2008 | Nintendo DS Console
Olympus Stylus 790SW Digital Camera Logo
508 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
