our fridgidaire gallery dryer squeals very loud for about the first 5 minutes of being on then quietly finishes it's job. It does this with each new load.
You could have a belt that is slipping on the heavy load of clothes when you first start the dryer, if so you may need to replace your belt.
Your problem sounds like drum rollers is in need of lubrication. If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers. Check your rollers for flat spots, if they have flat spots on them replace them. If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. Good Luck, I hope this helps
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if...
(More)
I am thinking of buying a Kenmore 600 Series TL Dryer QP2 or the 700 Series. Can anyone tell me if these are good models or if there is any problems with them. Thanks...Jan
My GE profile dryer is getting really hot, hot on top, hot inside drum clothes are too hot too...
(More)
My GE profile dryer is getting really hot, hot on top, hot inside drum clothes are too hot too touch, but nothing is dry. I cannot tell if the air is blowing or not. I have cleaned, vacuumed out the lint trap and checked the vent leading outside.
zanussi condenser dryer tce7276w on/off button and low heat button both have been pressed in and no...
(More)
zanussi condenser dryer tce7276w on/off button and low heat button both have been pressed in and no longer operate.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
