Question about RCA HD52W59 HDTV Projection Television
RCA 52w59 projection fuse fl231
Thanks to those that helped me find the problem with the tv. just need one last thing.... the spec on fuse fl231. It says t400ma, which I assume is .4 amps. Anyone know the voltage and any other specs I need n ordering this fuse? Possible site to order from? Thanks to all.
  • 2 more comments
  • tyson218p
    tyson218p Jan 05, 2008
    rca hd52w59 ,,,, tv just turnd of will not turn on cn you help
  • jw96 Aug 14, 2008
    That fuse is near the "flyback" or at least thats what I believe its
    called that . it is a small square fuse that is solidered in to the
    board and is the middle of the 3 in the group. I was able to jump it
    from the underside of the board to test it and as soon as I did the
    converegence menu came back and the set worked. Good Luck
  • gibs4 Jan 28, 2009
    I am just wanting to know how you jumped the fl231 fuse, and what you used to jump it with?
  • gajeep May 23, 2009
    FL 231 is a flat part in a group of three. It is the middle one and is red in color. Make sure your flyback solder points are good or the fuse will blow again. Your best bet is to resolder the entire flyback, as some cracked points are hard to see. The flyback is the big component with red wires coming out of the top next to fl231.
    FL231 is the only component needing to be replaced when dealing with a 3d look and no autoconvergence menu. The fuse is only .99 cents at Digikey.com.
    What does this look like? Is there a schematic that can be emailed to me? I whent to Digikey and typed fl231 in the search and nothing came up?
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Posted on Mar 01, 2010
  • Ninjanuts Apr 10, 2012
    Thx ill try that tonight ill repost if it works
  • Ninjanuts Apr 11, 2012
    It worked good i got auto convergence back but tv is still bowed and a little out of focus any clue on what i can do? Or did wrong
Posted on Feb 01, 2009
Can you tell me where in the TV I will find fl231 and can you tell me what the fuse looks like? Is it flat...round or what? In my TV, on the circuit board, there is a flat red (what looks like a copassitor) item marked fl231.
Posted on Aug 14, 2008
    Genius:
  • 1,030 Answers
Fl231 is a 125 volt. 400ma fuse rca part number 259513
Posted on Dec 28, 2007
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
FL231 Concergenc Fuse blowing
Check the ballast. Also make sure that it is plugged into a GROUNDED surge protector!
Jan 06, 2009 | RCA D52W23 52" HDTV CRT TV
I need to replace FL231 fuse.
Yes you must take back off and NO do not lay set over! POwer/deflection board is first board on bottom to left on right side bottom SSB board. FL231 is located on right side of FBT it has 2 wires coming out from it red/black(3) fuses look like small brown caps right in a roll it will be the middle fuse
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
Images doubled and red blue green colors all seperate
Look in menu go to setup see if you have convergence listed on menu if not you have open fuse FL231, located next to flyback on right side there is 3 in aroll small brown looking caps middle one is it FL231.
Dec 16, 2008 | RCA HD52W59 HDTV Projection Television
Where do you find this fuse?
the fl231 fuse problem can occur with movemtn of tv. Its caused by brittle connections. I get my special fuses from union electronics 1800 648 6657 or google the rca part 259213 check out my article in my tips and tricks section to determine if you have the fl231 problem if you dont have the convergence option in under setup in customer menu. then i would say you do, this is caused by bad solder connections and you wil have to solder this part in.
Oct 05, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA HD52W59 HDTV Projection Television Logo
2,254 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
