Question about Dynex DX-E401 Router
Router we got the internet to run thru the router but are unable to configure the router. It says that it can't find the page when we put in the 192.168.1.1
Hi, I have the same router, try to reset the router for about 20 sec, then follow the manuel instruction.
Posted on Feb 29, 2008
    Problem Solver:
  • 10 Answers
On my Dynex <different model> the IP is 192.168.2.1.
You should only need to type "192.168.2.1" (NO QUOTES) on the address line of your browser.
<GOOD LUCK> David
Posted on Jan 25, 2008
    Scholar:
  • 112 Answers
Wijth the router CAT5 cable connected to the host computer, open internet explorer on the host computer, in the address window type http://192.168.1.1 then press the ENTER key. If 192.168..1.1 is the correct IP address of the router you will get the logon screen of the router. BPCS
Posted on Dec 28, 2007
Unable to access internet thru router
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 15, 2010 | D-Link Computers & Internet
Cannot connect to internet, already configure my wireless CWR-854, thru 192.168.1.254, when im in internet, my deafault gateway is 192.168.1.1, please help
online user manual is here http://www.cnet.com.tw/download/cwr-854.htm If you goto page 37 it show the dhcp range . Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11 try this Start>run{vista/7 search box}>cmd>ipconfig /release Start>run{vista/7 search box}>cmd>ipconfig /renew see if that produces the correct info
Mar 20, 2010 | Cnet CWR-854 Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I can access the internet thru cable but cannot
Go to router configuration page (http://192.168.1.1) and find in options: Connect to Internet or something similar
Nov 26, 2009 | NetGear WNR2000 Wireless Router
I tried to connect internet but i could not configure my modem..
are you trying the same address of the router?
with which browser you tried?try changing it and use internet explorer.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Still unable to access router setup page
Get a refund and get a new router ( NOT a belkin one ) get an airport extreme or possibly a linksys or netgear or a draytek
May 27, 2009 | Belkin (F5D7231-4) Wireless Router
My computer down stairs says im connected to the router upstair,but i can,t connect to the internet down stairs.is it my wireless n usb network adapter.
Try putting the router ip address in your browser address bar, if the router configuration page is displayed this would normally mean there is not a problem with your wifi connection.
Most routers will from these pages indicate wether you are connected to the internet successfully if you are unable to determine this from the indication lights on the router.
Mar 25, 2008 | Computers & Internet
Support
Try these steps:
1. First of all connect your PC Directly with Modem & check if you're able to go online or not.
2. If No , then contact your ISP.
3. If yes ,Disconnect CAT5 cable coming out of Modem from PC & connect into WAN port (on rear panel you'll find it) of Linksys WRT300N Router , After that on rear panel you'll find small hole with a Reset button inside it. Use needle or pen to press it quiet hard for 1 minutes continuosly, This'll restore all default settings.
4. After that give static IP - 192.168.1.2 to your PC ,subnet mask 255.255.255.0 ,default gateway - 192.168.1.1 & connect your PC directly with a LAN port on the back side of Router.
5. After that type 192.168.1.1 in the address bar of your explorer & login window will come , type username = admin & leave password field blank, then you'll get Blue coloured Router configuration page, From this page you can configure your Router.
6.Now if your Internet connection is Cable then default setting will work for you, However for DSL connection ,on this page you'll find internet connection type - selectiondrop down box - select PPPoE into it for DSL connection.
7. After that restart your computer & you should be able to go online.
Jan 07, 2008 | Linksys WRT300N Wireless Router
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
65 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
