Changing the amount of rings
How do you change the amount of rings ours rings 3 time but we only want it to ring 1 time it is a hp 3050 laserjet
  • 1 more comment
  • Corrinne Schmidt Dec 29, 2007
    Great instructions very easy to understand ,worked !!! thanks for the instructions also Thanks for answering so quickly .
  • sugerplum Jan 10, 2008
    My fax machine is a muratec m2500 it does not have menu/all in one button. It is an older on I've probably had about 1o yrs. I need help changing the # of rings on the machine. It is just the phone and fax machine together on front it has buttons a-e down the left side and on each side of the number buttons has additional buttons for tone, flash, redial, program, ect.. I tried to use the program button and i'm almost sure that is where it is but once I get it to the settngs I cant getit to go to any additional screens. I'm notsure how to activate screens. ANyway if you can help me reset the number of rings for answer of fax that would be great.
    Thanks
  • Anonymous Apr 16, 2008
    I have one line for phone & fax, and a splitter. The fax is set up for 2 rings, so when someone phones, it only rings twice then goes to the fax machine, rather than voice mail. I haven't been able to find in the menus where to change # of rings, if it is even possible.
I have a canon cfx-l4000 and don't know how to program in the speed-dialing numbers and names...
Can you help me out?
Posted on Mar 05, 2008
  • 1,113 Answers
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Posted on Dec 28, 2007
  • Soulvisitor
    Soulvisitor Dec 29, 2007
    Cheers thanks for bothering to rate so many dont :-)
    S.
Why can I send a fax but cannot receive one. When the line rings, it always says no fax detected.
Ensure that telephone line connector inserted in line in port(other than telephone symbol port)
In fax settings..
select automatic in answer mode
select ring to answer as 5 rings
select ring mode as all rings(single,double & triple rings)
try for incoming fax.
Dec 17, 2015 | HP LaserJet 3050 All-In-One Printer
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Change amount of times fax rings before receiving fax hp laserjet 3050
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf Page 123
To set the number of rings-to-answer To set or change the number of rings-to-answer, use the following steps: 1. On the all-in-one control panel, press Menu. 2. Use the < or the > button to select Fax setup, and then press . 3. Use the < or the > button to select Fax Recv. setup, and then press . 4. Use the < or the > button to select Rings to answer, and then press . 5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press .
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | HP LaserJet 3050 All-In-One Printer
HP 3050 Laser Jet: I can receive faxes but can not send fax? Help
Hello !
You need to reset fax settings first, go to the "Service" under the printers Main Menu and click on "Restore Defaults"
And then set the following settings under Fax Setup > Fax Receive Setup :
Answer Mode: Automatic
Rings to Answer: 2
Distictive Ring: All Rings
Now go to "All faxes" and change this settings:
Error correction : OFF
Fax Speed: Medium v.17
If you are using a digital line it would be a good idea installing a filter for the line
Hope this works
You can contact me on :
eliteprintersolutions@gmail.com
Jan 08, 2010 | HP LaserJet 3050 All-In-One Printer
Unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
We are installing a HP Laserjet 3050 fax machine on the fly...
  2. Use the < or the > button to select Fax setup , and then press Menu .
  3. Use the < or the > button to select Fax Recv. setup , and then press Menu .
  4. Use the < or the > button to select Rings to Answer, and then press Menu .
  5. Change the number to 1.
Enjoy the solution
Nikhil Gedam.
Dec 08, 2008 | HP LaserJet 3050 All-In-One Printer
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
Phone Calls going to the fax machine
There is a PDF file on the CD. It may be helpful. When you set up your fax, did you set your ring-to-answer 2 rings more than your message system? If you don't have the CD, I can email you the PDF file. outlawdj_38@yahoo.com. Let me know.
Feb 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
How to receive fax on my home phone
V.34 'off'
Nov 19, 2007 | HP LaserJet 3050 All-In-One Printer
629 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
