Question about Canon CD-4050 Path-Through Scanner
Canon cd-4050 Scanner has message to change battery, How do you reset error message after you change the battery.
  • 1 more comment
  • aalafalot Mar 21, 2008
    Please elaborate! Huh?
    Quit then on the smaller window that comes up tap L, L, R, L?
  • kshaw Oct 07, 2008
    I had the same problem. Now the scanner window freezes and the disk won't come out!
  • tbellamy Jan 20, 2009
    Changed the battery, but stiil receive a message at power-on "battery Life Exceeded. Panel shows inatalled Dec. 2006 and to be replaced Dec 2008. How do I update the install and expire dates?
On the main screen tap the "QUIT" in the upper right hand corner of the scrreen. This should bring up a smaller box asking "Are sure you want to quit?" with a "Cancel" and an "OK" tab. Do not select either tab, instead tap you finger on the left side of the small box twice, then on the right side once, then again on the left side (L L R L) in rapid manner. This should bring up a small box stating you are in "Service Mode", tap "OK". This should bring up a box with 3 tabs at the top. Tap the "Battery" tab. The next box will have a tab on the lower left side "Exchange Battery", tap it, then tap "OK" on the next screen. This should set the battery install date to the current date and the expiration date 2 years out. Back out and shut down and reboot. You should no longer get the "Replace battery" message. The screen should display the new dates for the battery.
Hope this helps.
Posted on Jan 21, 2009
The last two guys were almost right. You need to have a mouse plugged into the unit. Then turn it on. When you get the battery needs to be replaced, use your mouse and click okay. Next you will click on the Quit tab, in the top right corner. When the "are you sure" Quit box appears use your mouse and click 2 times on the left side of the box, then one time on the right, then one more time on the left. You don't have to be fast doing it. Hope this helps, cause I tried 100's of different ways.
Posted on Oct 08, 2009
Quit then on the smaller window that comes up tap L,L R,L reasonably fast to go into service mode.
Posted on Jan 23, 2008
I have a minolta 4050 that is showing a 601 error code
SC 601 = SCP board PWB J malfunction or scanner motor malfunction.Scanner motor located in rear parts right side and the PWB J panel in the right side of copier.Try open and closed the front door,push the trouble reset switch,if the error code persisit change the scanner motor or PWBJ.Move the scanner manually,turn ON the power switch,if the scanner exposure lamp move,working the scanner motor is OK.Check the scanner home position sensor.
Oct 30, 2011 | Minolta EP4000/5000 CS/PRO Copier
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
Scanner won't feed
Fan the documents and check if they are loose. Stapled documents can be 'sticky' even after removing pins. Clena the pick-& ****** up rollers. Switch off the scanner and rotate them by hand so that all areas canbe cleaned (In power-on position, they are locked), If worhout replace them. Normally they last about 250,000 scans. Using a damp cloth is generally enough, dont use solvents.
S. Mohan, India
May 20, 2009 | Canon CD-4050 Path-Through Scanner
Canon NP 4050
I use this one
precisionroller.com
Oct 19, 2008 | Canon NP 6050 Copier
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
CD-4050 Scanner
First scan a single page and note the file size. Then scan two pages and check if the file size is changed. If the file size is changed, then you have problem with your viewing software. If the file size is same, then check your setting in the scaniing software.
S. Moha, India
Nov 29, 2007 | Canon CD-4050 Path-Through Scanner
Canon CD-4050
Try plugging in a key board and hitting the escape key, works for me every time.
Once in you can goto the Tools > Admin and adjust the domain settings.
Jason
Brandon, FL
Nov 08, 2007 | Canon CD-4050 Path-Through Scanner
354 people viewed this question
old marine
old marine
