1988 GE 8-2062 tv volume and remote problem
Hi, I have an old GE tv, with very little markings to tell what it is. It just says Model Number 8-2062 Serial Number 830446183 and Chassis number CTC136G Manufactured July 1988. It also says Thomson Consumer Electronics, Inc. at the top next to the GE logo.
The problem is the volume randomly jumps to 2x volume. I will be laying down watching TV and it will all the sudden BLAST! Pressing the down volume button does not help, it can only bring it down to the loudest the tv could 'normally' get. Its like it just went up to the second level in volume or something? Smacking the sides used to help for a few minutes to a few hours to a few days, now it does not help at all. I took the cover off and vacuumed but it didn't help. Nothing seems to be wrong, to loose connections, no blown capacitors, no burn marks etc. I'm thinking maybe a voltage regulator or an IC chip?? The sticker on the inside of the case only shows a schematic for the main board, not the side board that the speakers are plugged into. I have found that if I unplug the speakers when the tv is blasting, let it blast for 2 min, turn it off, then plug them back in, it will work okay for numerous house. But when I moved it from the basement back to my room, it did it again. So I repeated the process and it appears to be working okay for now. I am hoping to find a permanent fix, besides new tv and keeping the speakers unplugged.
Also, once or twice the volume/channel buttons on the tv swapped, another time the channel changed by itself, and sometimes the green lettering for the tv channel number turns black. The other thing is that a universal remote has no effect on it, even with the right code for a GE (works on our other GE tv, and no I don't have original remote). I think the remote sensor in the tv is dead.
So does anyone know the answer to my possessed tv problem? Maybe a fix perhaps??
Any ideas appreciated ;)
thanks,
- Dave
MikeNJ1964
  • 398 Answers
SOURCE: No Sound
9 times out of 10, the symptom you are describing is the result of something not being set right. First, eliminate any cable box or dish reciever issues by running the cable directly to the TV or using a VCR to play a good pre-recorded tape. Then go through the audio menu and make sure the speakers have not been set to OFF and also make especially sure that the TV is not in the SAP mode. If you eliminate all of the above and still have no audio then have the set serviced by a qualified tech.
Posted on Jul 24, 2007
  • 4 Answers
SOURCE: volume goes full blast when turned up from zero to just a "1" onscreen
I have seen a similar problem. get to design mode (that trick with the remote mute & the set menu button) & look for a data address in the audio section that is set to all (F)s. sorry i can't remember the exact address. you could always just guess just make sure you write down where they are currently set .
Hope this helps.
Posted on Jan 28, 2008
  • 84 Answers
SOURCE: Sound is ridiculously low
if it is a stereo tv, there should be rca jacks on the back of the tv [red,white yellow] try connecting the rca outputs to a stereo system and see if the volume is any different.there might be a loose connection to the tv speakers inside.if you have a cable box hooked up to your tv, check the connections in back. you can also try bypassing the cable box by connecting the cable wire directly into the tv to see if it's the tv. if it is the cable box try unplugging it for a minute then hook it up again.i had the same problem with my cable box. hooking it up to a stereo system sounds like a pain, but at least you will have sound.
good luck
wg
Posted on Jan 31, 2008
  • 927 Answers
SOURCE: volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Posted on Jun 13, 2008
SOURCE: RCA tv doing various things by itself
haunted house. contact an exorcist
Posted on Jul 13, 2008
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Universal Remote Control Codes
www.remotecodelist.com/
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
The reduce volume key on my GE remote to my GE (model 20GT360) TV doesn't work. Can I buy a new remote or get a universal remote? I don't know the code.
If you are certain that your remote is defective, consider buying a GE universal remote as a replacement. The instructions that come with the replacement remote will tell you how to get it working with your TV
Feb 05, 2013 | Televison & Video
Cannot change from video mode as we have no remote. We have a GE TV model 31gt660 which was hooked up by Direct TV. However, when the boys decided to hook up a flat screen to watch the fights the GE was...
My only suggestion would be to purchase a multi-functional remote that you could program to your TV. Now some remotes have to be programed buy your old remote. That is not what you need. You need the kind that comes with a little book that will list your tv model number and give you a code (usually 4 numbers) to teach it to talk to your tv.
Sep 20, 2010 | GE 31GT660 TV
What is the ge universal remote code for a symphonic tv?
You need to supply the exact make and model of the TV and the model number of the GE remote. The code cannot be determined without this information.
Thanks.
Jan 02, 2010 | GE Televison & Video
How to program model # 15-2135 to a GE tv
We have a 15-2135 not a 42. Just tell us steps to do to get code into it for a GE  TV
Jan 17, 2009 | Radio Shack 15-2142 Remote Control
Regarding the one for all remote
Hello mommy,
If you purchased the One-for-All universal remote (model URC4220) the remote code for a Proscan TV is either 0047 or 0747. The instruction booklet also has a section called ''Troubleshooting", which gives specific instructions on how to correct the problems you are having with volume and channel selection.
If you did not purchase the remote control listed above, please tell me the brand name and model number of your remote. I also need to know if it is a universal remote or not.
Hope this info helps you out. Please take a moment, whenever possible, to rate this solution, by using the rating system below.
Thanks.
Aug 20, 2008 | Proscan 19LA25Q 19 in. LCD Television
Volume up button does not work
Lynn, common problem on your chassis, problem is the tact switches are no longer available, (I checked and the remote is NLA also), the good news is any tv shop probably has some of these in their "boneyard", call up some of your local shops and tell them model # and what your problem is I`m sure one of them will have a few control boards kicking around, cheap fix, hope this answers your question, Happy Holidays, BMW Rider
Dec 07, 2007 | GE 46GW 948 46" Rear Projection Television
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Televison & Video
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
