Re: 2003 lincoln navigator reverse sensor no longer...
This sensor can be turned on and off. When in reverse look at your digital display and see if it is in the 'on' position. If not then tap the reset button to turn it on.
Question edited for clarity.
Question moved to Yes, Model category.
It is one of the most complex electrical systems on a modern vehicle. You will only get the full wiring in a service manual or from a subscription with AllData. You can however usually bring up part wiring diagrams. The search query is
Condenser? What type of condenser? The AC condenser is in front of the radiator. Condensers don't have fuses, they are like a radiator for AC refrigerant gas to cool it, before going to the compressor.
The Power distribution box is located under the right-hand side of the instrument panel. ... To remove the trim panel for access to the fusebox, pull the panel ...
You're shifter indicator appears to need attention. The PRNDL = Park - Reverse = Neutral - Drive - Low These are the gears. You need to have a high end electronic pc test and see what error code it is 'throwing'
yes it would cause the check engine light to come on.But just find the bleeper and remove it it want affect the cencer.The bleeper is separate from the censer..
The navi has leveling sensors on both axles that are switches and are adjustable. Most likely these are out of calibration. DO NOT attempt to move or adjust these with the vehicle on jack stands. Vehicle could shift and fall resulting in serious injury.
