TEAC 2300S
2300S won't go forward or reverse. Relay chatters when in forward. Seems like solenoids aren't getting voltage. Don't have a schematic;anyone have one. Lakemoses@Comcast.net
    Guru:
  • 1,894 Answers
Http://www.angelfire.com/electronic2/vintagetx/manuals2.html
found manuals for low cost here...
Posted on Dec 28, 2007
Looking for a free Teac A-2300S user manual
Hi man her is a link for your manual user system hi-fi
Download free
http://www.hifiengine.com/manual_library/teac/a-2300s.shtml
Oct 30, 2016 | Teac Audio Players & Recorders
Gas 2007 Ezgo has new battery but won' crank. Clicks in forward and buzzes in reverse
Sounds like bad solenoid or starter, but you may get better answers by posting in the correct section. This is for cars and trucks.
May 28, 2016 | Cars & Trucks
Playback low in one channel in reverse playback only forward playback fine. unit has been cleaned and lubed
Hard to say, but the three leading suspects would be:
  • dirty relay or switch (whatever switches between the forward and reverse heads)
  • bad head (so worn that one channel just doesn't produce as much signal)
  • bad electrolytic capacitor in the reverse-head preamp
None of these qualifies as a quick fix and all of them would require an oscilloscope or high-sensitivity amplifier for troubleshooting.
Aug 05, 2015 | Teac Audio Players & Recorders
Shudder in reverse and seems to be slipping forward gears good
It is an auto I take it and the problem will be a reverse band/clutch pack solenoid servo. It it is a manual then the clutch works the same way in forward and reverse so if it was slipping in reverse ,it would also be slipping in forward gears as well. Run the fault codes to check for TCM and servo/solenoid faults.
Aug 18, 2014 | Cars & Trucks
2010 craftsman 46" w/ kohler 22hp engine, problem: starter solenoid chatters rapidly when switch is turned. starter does not turn. replaced solenoid w/ no change?
the solenoid chatters due to voltage drop. Check battery charge & condition, and check battery terminals and connection to ground and the solenoid.
Nov 08, 2013 | Craftsman Garden
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
I have a Teac A-6300 that won't go fast forward or reverse but the capstan motor is running
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
Apr 14, 2012 | Teac Audio Players & Recorders
With TEAC A-2300s. Install new tape from supply side to take up side.
It goes from the left reel over the tension arm under the stationary guide in the head stack under the lifters between the Pinch Roller and Capstan shaft and then under the rigfht tension arm and threaded onto the reel. This is from memory but I am sure I have threaded 1000 or more decks in 40 years of service.
Sep 01, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
I hae a electric heat pump and gas furnace, when utilizing the heat pump i get chattering from a relay, i have replaced this relay with a new one but continue to get chatter any ideas
chatter on a relay can mean a few things but since you have just tried to replace it, i wouls check the voltage at the relay,,,,
chatter is caused by i mproper voltage at the relay, coil,
Nov 03, 2009 | Heating & Cooling
169 people viewed this question
 Grubhead
Grubhead
