Question about Sony KP-53S35 53" Rear Projection Television
Loud pop, and no more picture???
I guess im looking for some help here. i was called about a sony kp-53n74 that experienced a popping noise, and then no longer functioned. i know alot about electronics. from crt repair, to actual board engineering. but im looking for any guidance, as i dont work on rear projection tvs. thanks
I don't know if this will you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solution was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
I was able to increase the distance to the ground source by bending the bar away. Then I scraped and scrubbed the board with contact cleaner to remove residue and replaced jumper wire.
Has worked fine since.
Posted on Feb 23, 2008
I hear a random clicking sound when im on the phone but the person on the other end doesn't hear it
View topic - Loud clicking noise randomly during phone calls - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13207
Jan 19, 2012 - The clicking noise can only be heard by myself ... ... Loud clicking noise randomly during phone calls ... I have not tried calling from a landline.
Weird Popping/Clicking Noise during Call ' MacRumors Forums
forums.macrumors.com > ... > iPhone > iPhone
Jul 4, 2010 - I have experienced the same popping and clicking sounds. .... I want tohear if what your phone is doing to see if mine is the same. share.
How can I tell if my Phone is being tapped? - Nathan M. Smith
https://sites.google.com/a/.../howcanitellifmyphoneisbeingtapped
May 4, 2010 - I have heard clicks while talking to some of my friends across the country ... in use and i hear a crackilng sound.. what is going on... im not a criminal....... Even on my cell phone i will hear unidentified beeping and random dial ...
I keep hearing a clicking sound in the background - Tested
Jan 29, 2016 | Lands Phones
Sony 52 inch, model number kp 53n74, stopped working
I have the same model Sony TV with a September 1999 manufacture date just did the same thing Friday! How are we suppose to find out what's wrong
Feb 22, 2010 | Sony Televison & Video
Loud popping noise and spark coming from red projector
I would guess you have a High Voltage Leak at the Anode Lead Cap where it Mounts to the CRT. This is not a area to mess with You are better off calling a professional to fix it. It may be a little difficult to confirm if it is a intermittent problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 51F59 51" HDTV Projection...
Sound but no picture
Almost certainly the convergence IC's are shorted. Big job; perhaps $300 to $400.
Apr 09, 2009 | Sony KP-53S35 53" Rear Projection...
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
No Picutre
someone shot your tv.
no really, I am just a smart a$$ --- but the loud pop sounds like it may have been one of the capacitors in the power supply board. check for a POPPED cap (rare) and if there is one, test the components in the related circuit - as SOMETHING had to happen to make a cap fail like that - maybe a voltage regulator? give it a look..
Jul 25, 2008 | Sony KP-48S35 48" Rear Projection...
Sony KP-53N74 Rear Projection TV won't power up
how was the picture before ? nice and bright if was ok it may worth fixing probable just power board get the hit ..
May 16, 2007 | Sony KP-53S35 53" Rear Projection...
Sony KP 53S65 Rear Projection TV
I don't know if this will help you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solution1.gif was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
Mar 18, 2007 | Sony KP-53S65 53" Rear Projection...
Need to know part number or value for C514 in horiz out put circuit for kp-53s65
C514 has three different values possible. Just use this value as it has worked fine for me in the past. 680pf /2kv Sony part# 1-162-116-00
Jan 20, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
