Question about IBM ThinkPad 600X Notebook
Boot cycle over and over(is that redundant?)
Have had history of the 8611 problem
Now it says windows 2000 is loading , then after first progress screen shows progress bar in a splash screen, then solid blue screen, then black and reboots again(over and over)
What is it?
    Scholar:
  • 112 Answers
Sounds like the hard drive, make sure the hard drive is seen in the BIOS. If it is try a repair using the 2K disk. If this does not fix the problem. You will need to reload the O.S. These suggestions are only if you have an operational hard drive. If you have a bad hard drive, replace and reload the O.S. BPCS
Posted on Dec 28, 2007
I HAVE NO NEW XP WINDOWS RECOVERY CD FOR MY MEDION MIM2220 SO I CANT START WINDOWS , WHEN I TRY TO INSTALL FROM RESTART IT COME WITH THIS MESSAGE WHILE TRYING TO BOOT ( AN ERROR HAS BEEN ENCOUNTED THAT...
Do you have the original installation disk that came with the computer? You can try to boot from that CD and do a repair installation. The Cyclic Redundance Check (CRC) error refers to the media the computer is trying to access (either the CD or the hard drive). Try booting into Safe Mode (reboot and press F8 repeatedly until you get a boot menu). From Safe Mode run a checkdisk (chkdsk from command line) on the hard drive to find and repair any found disk issues.
May 25, 2011 | Medion (40010998)
Tip
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
on Sep 15, 2010 | Computers & Internet
How do i reboot my computer my self.
Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows operating system before Windows Vista, or select the right arrow in Vista. Select the "Restart" option. 2.)Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer. 3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on. 4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder. Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
All the Best!
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
Boots to progress bar before loading windows
It seems that windows tries to check your Hard Disk for errors before loading the system files to memory. Do you hear some sounds from your hard disk? If you can successfully get to windows, open my computer => right click on drive C => Click on Properties => Click on TOOLS Tab and click CHECK NOW button.
Check the next 2 options and answer YES when windows ask you to schedule a thorough scan during next boot.
Regards!
Jul 21, 2009 | Acer Aspire 5100 Notebook
It says there are error codes 163, 8611, and 163 time and date pop up but if you try and pass that it freezes and shuts down again. please help
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
Jun 14, 2009 | IBM ThinkPad 600X Notebook
Tekken 5
your game is loading the history of your progress and saving at the same time. this is how it keeps your progress.
Apr 23, 2009 | Namco Tekken 5
After loading windows 2000 progress bar computer restarts
Hit F8, enter en safe mode, and clean the computer and unistall the last program installed (if any) Be sure also that your computer is not infected by virus or spyware.
If after that the problem continues, you need to use your windows cd and use the opcion (R) recovery console.
Nov 13, 2008 | Dell Dimension 8200 PC Desktop
Failure to boot an Extreme Networks 8808
It sounds like...am afraid... the switch may may be developing multiple sclerosis on its circuitry or the processor is losing it. have it checkd.
Nov 06, 2007 | Extreme Networks (45210) Networking Switch
IBM ThinkPad 600X Notebook Logo
78 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
