Question about Yamaha RX-V595A Receiver
Yamaha rx-v595a problem with dts signal
I have a yamaha rx-v595a. The other night I must have accidentally pushed a button on the front of the unit in the dark, and now I can only get sound when the input is set to analog. If I select Auto or DTS no audio is played even if I am playing a DTS disc and have the player set to DTS. I think this happened once before, but I do not remember how I fixed it. I have been through the manual and cannot find anything that works. Any ideas?
Thanks,
Shawn
Moi au debut je n arrivais pas a avoir le signal dts je suis passer en optique et plus de soucis
Posted on Jun 03, 2008
  • 95 Answers
The unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Posted on May 26, 2008
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Yamaha receiver shuts off automatically after two seconds. Changing Inpedence switch has no impact.
Does disconnecting all the speakers make a difference? If so, troubleshoot the short out to a speaker.
If not, it's due for a trip to the ER.
Dec 31, 2010 | Yamaha RX-V595A Receiver
Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
Mar 09, 2010 | Yamaha RX-V595A Receiver
Is there any DTS decorder player that suit with Yamaha RX-V 2090? Thank you.
Try the Technics SH-AC500D Digital Surround Processor. Its outputs should match the inputs on the RX-V2090. I own both units, though I am using a DDP-1 with the Yamaha receiver. I use two separate amps with the Technics to achieve surround sound using my good vintage stereo system (two of them actually - one for front and ane for rear). The Technics is a nice piece of kit.
Aug 13, 2008 | Yamaha RX-V2090 Receiver
Reciever won't switch back on
you need to take it to the nearest yamaha service centre. Unit could have had a surge or blown a fuse.
Mar 25, 2008 | Yamaha RX-V595A Receiver
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Oct 27, 2007 | Yamaha RX-V595A Receiver
Yamaha RX-V595A Receiver Logo
226 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
robert landry
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
