That error means the purge assembly is stuck, you need to pull the carriage out of the right corner and look inside with a flashlight. Usually a paper wad in there, if not you need a new purge assembly.
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor. Check out this link: Brother for further information.
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message. [email protected]
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
