Put a load of pants and sweatshirts in the washer, hit start and it started for a brief minute then it went into pause mode and on the display it read do then about a minute later the display read fl but the door will not unlatch at all. What do I do?
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it....
(More)
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it. None can figure it out. Please Help. The wash runs up to the spin cycle then just stops.
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control...
(More)
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control panel says ''End of cycle signal ON/OFF'' Machine control connector/wire = P5 (WH11) & P2 / 1 (PU21) 24VDc ON O Vdc OFF; Timer Contract = Not Involved. Does this mean the board is bad because the Timer is not involved?
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine...
(More)
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine seems to be willing to keep filling, even while it is in 'drain' mode.
