I have a hunter programmable thermostat model #44155c and Im trying to wire it to my goodman furnace. Its a 7 wire system with a white,yellow,red,green,brown,blue, and orange wire. The ac works fine but the heat wont shut off. Thanks
Make sure you do not have a jumper between the red and the white. Also make sure the wire is not hanging out from behind the screws. If the heat stayes on no matter what you do. The red wire has to be touching the white somewhere.
The red is your 24v supply to the thermostat
The white is what sends the 24v to the heat side of unit.
Just a thought. If the thermostat has a O/B pin or switch on the back. Make sure it's on O. It should only be ob B if it's a Trane, American Standard or Payne.
Was this helpful?
Yes
No
Popular Solutions for LG LSC183VMA Split System Air
usually there is a blue wire to the thermostat but in this case it is not. instead there is a black...
(More)
usually there is a blue wire to the thermostat but in this case it is not. instead there is a black wire. i used that one as blue. now there is no heat. it is a hunter cool/ heater unit.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
