Question about Jabra BT350 Bluetooth Headset Headset
Doesn't work! It's a brand-new unit and I am unable to charge it! After I plug it in the red light flickeres for a millisec, then the green light flickeres for a millisec and then... nothing! I thought it came fully charged (unlikely) but pressing the answer button does... you guessed it: nothing! Please help! Thank you.
  • 3 more comments
  • scooter78 Dec 30, 2007
    its been charging for over 12 hours and nothing has happened, the light is still red, whats the deal?
  • meusha Dec 30, 2007
    Brand New JAbra bluetooth doesnt work. It does not charge. It doesnt show any light even if hold it for some time. It doesnt show any light if we put for charging.
  • tymtw12 Jan 03, 2008
    I have the exact same problem. I connect it to the wall outlet charger or usb charger and the light flickers green/red for half a second and then nothing happens. Pressing the on button does nothing either. The unit is brand new.
  • pjsafe67 Jan 03, 2008
    I am also having the same problem, though my headset is not new. I got it in February of 2007 and I have never had any problems until now. I plug it in to charge it and it does nothing. The light comes on for a split second and then goes off. The unit will not turn on or charge.
  • BecsWard Jan 16, 2008
    I too have exactly the same problem. I can't pair it to my device as its not charged in order to do so. How to resolve?
I had the same problem. You may have it plugged into the device backwards. Remove and flip over and plug in. That happened to me. Hope this is all of your problem.
Posted on Jan 20, 2008
I've gotta solutionDoesn't work! - 1.gif for you. I had the same problem and what I have found out is that if the headset4.gif does not go charged for an extended period of time, the battery needs to get a kick started so that it will accept a charge. In order to do this, you have to remove the blue plate with a small screwdriver first. Then with an extremely small torx bit take off 2 screws that were under the blue plate. Next remove the board from the shell, but not so much as to disconnect them from the soldered components.
Here's the tricky part. You will see the 150 MAH NiMH battery with a + and - post right on top of it. the connections are about 1/8" thick. You MUST HAVE a battery charger that can manipulate the current and voltage while charging. This would be like a peak charger for an R/C car of which I happen to have. The Jabra battery is NiMH and you should be able to set it to that instead of the NiCd. Set it at 150 MAH, and Delta Peak at Auto and in 10 minutes its charged and ready to go. After you put it all back together, you can then again charge it as you normally would with the AC charger or USB connection. I believe the majority of DOA headsets4.gif are due to being on the shelf for an extended period of time and not getting some charge.....eh it happens!
Gerald
Posted on Jan 28, 2008
    President:
  • 1,017 Answers
I suppose you have paired both devices to work together.
Posted on Jan 11, 2008
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Jabra BT350 Bluetooth Headset Headset Logo
331 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
