if the lights and turn table still work, then its either your h.v. diode,h.v. capacitor or the magnetron tube at fault, if nothing operates then its the internal ceramic fuse under tho outer unit cover thats bad or your outlet is dead at the wall
I have a 2 year old electric designer series Viking double wall ovens, The fan is operating even...
(More)
I have a 2 year old electric designer series Viking double wall ovens, The fan is operating even though the oven has not been turned on. all settings are off. Also, can anyone tell me how to reset the clock on the ovens?
Our Viking Professional single 30 inch electric oven model VESO 105, made around 2001, has annoying,...
(More)
Our Viking Professional single 30 inch electric oven model VESO 105, made around 2001, has annoying, loud cooling fan noise. Has anyone else experienced this problem? Found a fix? I'm told the newer Viking Professional ovens use squirrel cage type fans that are said to be quieter than my older model which uses traditional fans with four blades. Does anyone know if the newer Viking ovens do in fact have quiet fans? Thanks so much any replies; it's hard to find local people with Viking ovens to compare notes.
the microwave runs and sounds fine and the timer works, and the center turntable rotates, but...
(More)
the microwave runs and sounds fine and the timer works, and the center turntable rotates, but nothing is getting heated... no warmth at all??? any ideas to troubleshoot this problem? any reset solutions?
