Solution:
SOURCE: xerox phaser 8560 ERROR: 09, 038, 46:15112
Yep. One of your ink sticks is stuck in the ink loader and not advancing down to the bottom of the ink loader.
Look where you add the sticks, I think off hand that .46 means its a black stick, but anyway, one stick is broken, cracked, twisted or otherwise for some reason not sliding down the loader.
If you have to remove them, take a screw, a drywall screw is best to twist into the ink block and slide it back and out to reload.
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
SOURCE: system error on xerox 8560dn 09 038 46 8515
ink count sensor flags are stuck.verify the ink is correct and genuine and then reset the error by doing the following
1- turn the printer on
2- wait for the xerox logo to begin moving acroos the display
3- Before the logo is centered on the display (stops moving) press and hold the back and help buttons on the control panel.
4- Hold both buttons untill the display reads beginning service mode initialization.Release the buttons and the printer reboots into service mode with the Service Diagnostics menu dislayed
scroll untill you find function menu then click ok
scroll untill you find Clear ISC fault and press ok
click back several times and then reboot the machine.
Good luck and let me know.
SOURCE: System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
SOURCE: xerox phaser 8560 error 09:038:46:25836
That error code indicates a problem with the ink loader, 09.038 is the black chute. Make sure you are using genuine Xerox ink sticks and that the chute is clear of debris. Next enter Service Diagnostics mode by powering on the machine and hold the back and help buttons at the same time as it boots until it says it is beginning service mode. Once the menu is displayed, go to function, clear ISC Fault and press OK. If this hasn't fixed the problem you will need to replace the ink loader, part # 133K27771. You can buy one here. I will be making a video on how to replace this part later this week, if you need it let me know. - Steven
