Question about LG 24 in. LDS 5811 Built-in Dishwasher
The diswhasher is noise
The diswasher is noise after two month the installation why?????
    Novelist:
  • 148 Answers
Need to know what kind of noise. could be something caught in the pump. when does the noise occur relative to the full cycle. is it a rattle that happens once in a while, or constant when the pump is running.
while thinking about this, check the drain filter in the bottom and make sure there is nothing visible there.
let me know
mark
Posted on Dec 28, 2007
What is the most effective soap for thw Miele G870SC diswasher
the only dish detergents that work right now are the miele tabs, and finish has a product called finish all in 1 powerball. everything else on the market right now will leave your dishes dirty, and will leave residues behind making your glasses cloudy and your dishes dull. describe the noise better and i will try to help.
May 31, 2012 | Miele 24 in. G870 Built-in Dishwasher
People periodically get shocks from the metal sink , dishwasher?
Make sure the ground wire on the dishwasher has a really good connection.
Also the ground wire in the plug in receptacle.
Feb 04, 2010 | Dishwashers
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Water remains in the bottom of the dishwasher (18 months old). Disposal is clear, glass trap is clear. What should I look for?
First : if this started after a new disposal was installed then you need to check the Knock out on the disposal located inside the pipe that sticks out of the disposal where you conect your dishwasher drain hose. ((((( Common Problem )))))
Ok, moving on, your dishwasher has a independent drain pump. if you know the noise of the drain pump and you do not here it. its a good chance that its bad and you can disconect it and put a volt metert to the 2 wires and check for 110V. of coures after you have your volt meter in place and ready to go you will then put your diswasher in drain and check your meter.
Here is a breakdown of a dishwasher with a simialr model number. # 60 is the drain pump.
Jan 09, 2010 | Frigidaire PLD4555RFC Dishwasher
How do i get mold out of the diswhasher? Is it
I would try Hydrogen Peroxide first before the Clorox type.
Do not use CLorox WITH the detergent at the same time.
You could also run a very concentrated detergent dishwasher load.
Oct 19, 2009 | Frigidaire Dishwashers
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
My LG makes noise during operation.
The only way to access the motor either the drain motor or the wash motor is to pull the diswasher out, invert the whole thing, remove the access pannels. If you are going to remove the entire sump assembly, be real careful as you remove the screws, because the law of gravity promises to crash the sump down onto the "top" of the diswasher.
The Parts waranty is 24 months. But with the motor being repaired by an (factory authorized?) you may be able to get LG to cough one up.
Look carefully at the failed motor, write down the horse power and amps spec. Compare it to the new one. You should see a higher horsepower version. Good Luck.
Also, if you have _ever_ had problems with water leaking from the front door or the dishes dry poorly, get back to me with your model and serial number. Could have some good news for you.
Mar 31, 2009 | LG LDF6810 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
256 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
