2005 Pontiac Grand Prix Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the cabin filter located - 2005 Pontiac Grand Prix
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Oct 16, 2009
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2235811
Points
18738
The cabin air filter is located directly underneath the cowling at the base of the windshield on the passenger side of the car.
To access the cabin air filter, you will need to remove the cowling. First, open and lift the hood. Second, locate two plastic pins securing the plastic cowling at the base of the front windshield, on the passenger side. One is located under the wiper blade, near its base. Use a small screwdriver or similar tool to carefully lift/pop up two plastic pins securing the cowling, taking care not to damage the plastic pins. (You want to lift the pins, and not the anchors that look like washers beneath the heads of the pins. Carefully pull the plastic pins and their plastic anchors (once you pull the pin up, you can safely remove the anchor). Take caution not to damage the pins and anchors as you will need them to rescure the cowling when you are finished replacing the cabin air filter.
Before you remove the cowling, carefully pull back the rubber gasket and windshield washer fluid tubing at the base of the cowling. You can now safely remove the cowling, and you will see the cabin air filter below.
Remove the old cabin air filter and replace it with a new filter.
Reverse this process to reinstall the cowling, gasket, and pins once you have replaced the filter.
Anonymous
Level 3:
Brigadier General:
  • Master 7,353 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
7353
Questions
Helped
2485662
Points
23804
Under the right side of windshield, under the wipers..... turn the wipers on and turn the key off when they are UP. now take panel loose and the filter is under that panel.
5 Related Answers
Anonymous
  • 659 Answers
  • Posted on Dec 02, 2008
SOURCE: LOCATE AC CABIN AIR FILTER
no cabin filter on 2003 crown vic cabin filter is under pass cowl trim
Anonymous
  • 4 Answers
  • Posted on Jan 11, 2009
SOURCE: Cabin Air Filter Location
Empty glove box, remove axcess panel and the open the axcess door, two (2) filters inside,
Anonymous
  • 5 Answers
  • Posted on Apr 28, 2009
SOURCE: cabin air filter location
Its behind the glove box, yipee!
Anonymous
  • Posted on May 07, 2009
SOURCE: cabin filter element location
Filter is located behind the glove box. All you need is a screwdriver to replace.
1. Open the glove box and empty to take the weight off the box.
2. On the right side there is a plastic hinge like device held on by one Phillips head screw. If you have trouble removing with a Phillips screwdriver you can remove with a narrow flat head screwdriver. Remove the screw and slide hinge off the mount.
3. To drop the glove box press the sides slightly inwards while 'forcing' it open beyond it's normal stopping point. Careful as when it releases it will fall wide open and may even fall from its hinged area. Set it aside.
4. Behind the glove box there is probably some fiberous material inserted to prevent noise like squeaking when it rubs. It is sticky on one side to hold it in place. Just remove and place out of the way.
5. Behind the fiberous material there'll be a cover which kinda looks like a grille. Mine was white and it is in the center of the opening. Remove it by releasing the clips at the left or right. It comes right out.
6. When the cover comes off slide the filter out and replace it. The filter lays flat and just slides in and out easily. However, if it has been some time since you replaced be prepared for a lot of debris on top of the filter such as leaves, grass or other general type of debris that has been sucked into the filter. It also may be the source of any bad odors that you smell through the air conditioning system.
7. Reverse the process. Replace the cover and push the glove box lid back into place. When you replace the glove box be careful to make sure the hinge you initiallly removed the screw from is not left behind the glove box or you will have to remove again to get it out. Replace the screw and do not over tighten as it screws into plastic and then your done.
Anonymous
  • 7353 Answers
  • Posted on Oct 21, 2009
SOURCE: Location of cabin air filter on 2005 saturn relay 2
behind the glove box, after taking out the glove box it has a cover marked"air filter access doo"r
Testimonial: "Thank you for your help."
Cabin air filter location for a 2004 Hyundai Accent L
If it doesn't have AC you do not have the filter.
2answers
How do I replace the cabin filter
Hello there.
I found this
Ford F150 cabin air filter location. From year 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008.
Here you can find how to locate Ford F150 pollen filter when you need to replace.
Cabin air filter on Ford F150 is located inside the car on the passenger side.
If is first time when you change this filter you need to following this work procedure.
1.Remove the plastic panel (see in picture) for a easier access.
2.Install the plastic onto cabin air filter housing cover and use screw to hold this on position.
2helpful
Location changing instructions cabin filter 2003 pathfinder
For nissan pathfinder cabin air filter replacing procedure with diagrams:---
Click the link below:---
http://repairhelpcenter.blogspot.com/2012/12/2003-nissan-pathfinder-cabin-air-filter.html
These will help.
Thanks.
2answers
I cant locate the cabin air filter on my 2008 VW Beetle. I went to the location and its not there. There is a musty smell coming from the vents.
The cabin dust & polen air filter location & replacement
The cabin air filter is placed inside the car under right dash panel near windscreen. See pictures below:
4helpful
It can have a cabin air filter, but most vehicles ship without it. Either way, you can access the cabin air filter housing by opening the glove box all the way (squeeze the sides so it clears the stops).
The filters are around $15 at the dealer.
Whether or not there's a cabin filter installed, make sure you're also following Chrysler's recommendations in the owner's manual—running the air on recirculate all the time will encourage mold and bacteria to grow.
Good luck
4helpful
3answers
Would like to know where cabin air filter is located?
your cabin air filter is located under the windshield wiper cover on the passenger side of car open your hood to see the access panel
3helpful
3answers
Need to change cabin air filter
its nex to the brakes http://www.youtube.com/watch?v=0xcBGnP1vNY
1helpful
3answers
Cabin air filter Location
cabin air filter is under the golve compartment or under the cowl vent cover / Please rate my response thank you very much
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
