Question about MB Quart Reference RAA4200 Car Audio Amplifier
Missing Plugs The plugs that allow you to connect the wires to the amp... yeah, i'm missing two of the speaker wire ones... any suggestions?
I have a mbquartz 2500raa. If its a bridgable amp take each wire individualy and sauder each wire at the end into a ring large enough to fit around the plug ti area. When connected if sound is produced sauder each looped wire end to the plug area. Make sure to cover each wire with electrical tape so as to keep from arcking this is what i did with mine when i lost the plug.
Posted on Dec 28, 2007
1992 CHEVY ASTRO VAN KEEPS MISSING HUSBAND CHANGED DISTRUBUTOR , CAP , WIRE, PLUGS, COMPUTER AND STILL MISSING WHAT COULD IT BE
missing is not always the plugs ,HT leads distributor . Most times it is from misfiring injectors and low fuel pressure.
Mar 04, 2014 | 1999 Mercury Villager
High Idle
Replace plugs and wires.
May 25, 2013 | 1992 Honda Accord
2002 f150 with 4.2 ,runs rough after rain
very common problem with your year model is missing inner fender not sure why but if one is missing good chance when it rains u are soaking the coil causeing it to arch and miss fire or arching at connection at the plugs and wires if ur missing a inner fender dont waste ur time replaceing plugs, wires, or coil tell u have replaced the inner fender
Jan 11, 2013 | 2002 Ford F150 Regular Cab
Missing on number 3
Did you set the gap right on the spark plugs? Also double and triple check the wiring diagram for plug wires, because may have gotten one crossed. I would also check to see if having any vacuum leaks or broken vacuum lines since replacing wires, sometimes they become brittle and break.
Aug 12, 2012 | 2000 Ford Ranger SuperCab
Nitro bmw 4745
you are having problems with the wiring harness missing and cant find one right go to the junkyard and try to find one that that will plug into unit then you will have to figure out which wire is the power wire and acc and ground i assume you are using and amp so you dont need to find the speaker wires plug them into rca plugs and you should be good it will take some work but noone else has one BUT ME AND YOU!
Aug 11, 2012 | Nitro Snowboards Nitro Bmw4745 7" TFT...
There are three wires coming out of one of the speakers. One is connecting the speakers, one is green and plugs into the computer, and the third one is a short wire that I can't figure out where it goes....
Normally there will also be a wire that goes to a power supply / adapter.
You are probably missing the the part that plugs into the electrical wall outlet.
The third wire coming from one of the speakers will likely fit into a port on that power supply adapter. Just find the power adapter that goes with it and plug them in and they should work.
The speakers need a power supply in order to drive the amplifier circuit which makes them louder.
See the image at the following link to see an example of a complete system with power supply:
http://www.google.ca/imgres?imgurl=http://ecx.images-amazon.com/images/I/41Xxd7NTz4L.jpg&imgrefurl=http://www.computerspeakersbest.com/great-price-g-max-2000-for/&usg=__FUe0rFa9zlQOEUzfY7ppHHG3gMg=&h=300&w=400&sz=23&hl=en&start=14&zoom=1&tbnid=Kba8jPPwRWMiqM:&tbnh=135&tbnw=180&ei=dO6sTdOJCYicgQfJo-3wCw&prev=/search%3Fq%3Dcomputer%2Bspeaker%2Bpower%2Badapter%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1001%26bih%3D589%26tbm%3Disch0%2C618&um=1&itbs=1&iact=hc&vpx=127&vpy=255&dur=7141&hovh=194&hovw=259&tx=184&ty=121&oei=cO6sTYvMDei20QGFm9S1Cw&page=2&ndsp=15&ved=1t:429,r:10,s:14&biw=1001&bih=589
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the image at the website indicated.
Good luck.
Apr 19, 2011 | GE HO98010 Computer Speakers
I have a 2003 Santa Fe with 3.5 6cyl engine that is ideling rought & lots of missing off a stop. had codes PO001,03,05. Had wires & plugs replaced 2 weeks ago & still running rough. Now...
Do you mean P0301, P0302, etc? Misfire codes? You have 6 plugs, 3 coil packs, and 3 wires. cyl 2,4,6 are the ones in front, with the coil packs. It's possible they're bad.
Jan 20, 2018 | 2003 Hyundai Santa Fe
Do LF and HF +/_ both be connected and if yes do they both go to speaker system A or separate to A and B on the amplifier.
From the factory, those are equipped with "jumpers", one for red-red and one for black-black. This allows for one speaker cable to power one speaker.
The jumpers can be removed, allowing for "bi-wiring", where you run two leads from a single amp channel to both inputs on each speaker. There's also "bi-amping", using a treble amp and a bass amp dedicated to each input.
If the jumpers are missing, you can use a short piece of stripped speaker wire to reconnect the upper and lower binding posts, just be sure to match colors.clmrt5000_0.jpg
Jan 10, 2011 | KEF Audio Q55 Speaker
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Aug 18, 2010 | Jensen Car Audio & Video
Hello Need help on a 2004 Ford Explorer. Having problems with Ford explorer rough ideal & missing. Changed plugs & wiring. Used Gas treatment. Change fuel filter & air filter also.
You have an air leak at the intake. Spray a bit of starting fluid around the intake. The engine will respond when you hit the spot. Replace the gaskets as required.
Mar 26, 2010 | 2004 Ford Explorer
MB Quart Reference RAA4200 Car Audio Amplifier Logo
93 people viewed this question
Top MB Quart Car Audio & Video Experts
xxxxxx xxx
Are you a MB Quart Car Audio and Video Expert? Answer questions, earn points and help others
