Question about Bose (321GS) System
Bose 321 The remote stopped mworking. The units still works manualy. Changen the bateries and reset, and the remote did not worked at all.....
  • Anonymous Jan 04, 2008
    I have same issue. This happened on 12/31/2007 after 13 months of operation. Though remote is not controlling the unit, it controls TV. I went to BOSE showroom (Chennai, India) and remote worked perfectly with their GS display unit. Then I went to service center. Serviceman promised me to send a CD with software upgrade. I ran the CD to upgrade the software. No use. Now I have take the media centre to the service station. Anyone has solution?
  • bvasanth Jan 04, 2008
  • 4 Answers
I have same issue. This happened on 12/31/2007 after 13 months of operation. Though remote is not controlling the unit, it controls TV. I went to BOSE showroom (Chennai, India) and remote worked perfectly with their GS display unit. Then I went to service center. Serviceman promised me to send a CD with software upgrade. Let me wait for a day or 2 receive CD and test it. Have you got any solution.
Posted on Jan 02, 2008
  • bvasanth Jan 13, 2008
    No issue with remote unit. Service person checked and found a PCB (Printed circuit board) of remote sensor inside media center has gone out and replaced with new one. now it is working.
Bose 321 device code for Kogan UHD TV
Your Bose remote may not work with your Kogan TV.
Aug 12, 2016 | Bose 321 GS series II
Bose 321 dvd and remote
hello.
Clean out the battery connection inside the battery case. Incase this work disassemble your remote and find any fault connection in it. or let the repair man do it.
If the remote work change the setting press PBC mode this will change the color. or refer to the manual for changing view setting.
melnavz
Mar 31, 2008 | Bose 3 2 1 GSX System
Bose 321 sound fading
Try the following:
1) Switch the unit off completely, using the powerswitch on the back of the bass box.
2) Switch the unit back on via de switch on the bass box.
3) The display should read BOSE 321 and than be dark.
4) Insert a CD and switch the unit on with the remote by selecting the CD/DVD mode.
5) When the sound is now OK, it means that you need to contact Bose to ask them for the latest software update for your unit. After updating your system. The problem will not reoccur.
6) in case the problem continues and at start-up using a CD, no improvement of sound is heard, the system should go into repair. Contact Bose in your country and ask for return instructions.
Jan 13, 2014 | Bose Audio Players & Recorders
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
Aug 10, 2010 | Bose (321GS) System
Bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
Aug 02, 2009 | Bose (321GS) System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Jan 26, 2008 | Bose (321GS) System
My bose 321 system remote control sometime works and sometime doesn't.
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Bose (321GS) System Logo
912 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
