Question about Audiophase MDP-1 Personal MiniDisc Player
Audio phase would like to know first how to charge bat on this thing have left it plugged into the computer and no luck second can you tell me how to download the videos thanks vicki
My audio phase MP3 player says "flash error! please backup the data and format the player.'' What does that mean? how do you fix it
Posted on Jan 02, 2008
Charged batrie pet in checked spark plug plenty spark .turn key on not firing spary some east start still nothin
Check 3 things
I always start with fuel because that will eliminate spark and compression right off the bat...
Spray some carburetor cleaner into the plug hole then reinstall the plug ..
If the unit starts up and runs for a few seconds, you have a carburetor issue
Oct 15, 2015 | Garden
Problem is not charging
First you guys need to know that the HTC does not charge if the ROM is inconplete/damaged .
If your battery is really dead there is no initial power on the internal battery to manage the chargement.
So ... resolution.
Fist way .
If you know any one that may have an other HTC Diamond you need to swamp batteries so the good Diamond that has the internal bat ok and charge it there.
Second way . this one i did it my self .
Go to a Local ChinaMan store and buy a multimeter and a regular Universal Adapter.
Heres how it hoes ...
Use the Multimeter do figure out the polarity pin's on the battery ex: + and - .
remove / cut one of the plug's from the Universal transformer and also tag the polarity.
set the voltage to be close to 5 V - 1 Amp .
Conect the cuted wire from the Univ. Adapter to the Diamond Battery respecting the polarity.
Leave it for a wile..... ( Probably up to 1 hour but chec from time to time tme battery temperature and if possible a reading on the bat voltage levels.)
Put the battery bat and boot your diamond or turn on to boot loader.
**** Attention if you don't have more than 50% of the bat charge compleated you wont be able to flash your phone****
Jan 14, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
My dell xps m2010 charger not charging its battery but turns on my laptop when i plug the charger in.
most probably your battery is damaged! try another one in a shop and you will know for sure
Oct 27, 2009 | Dell My XPS M2010 Notebook
Motor is hot?
Which motor is hot...compressor or fan?
Also need to know the model number.
Is this a 3-phase or single-phase unit?
Let's assume it is the compressor...Is it so hot that you can't touch it for more than a second or two? Is the compressor shutting down on internal thermal overload?
Compressor body hot can be caused by a number of things:
1. Low charge (the freon acts as a coolant for the compressor).
2. Electrical imbalance (3-phase only). (check line-to-line voltages)
3. Bearings in compressor failing (check amp draw).
4. Condenser dirty or airflow blocked in some way.
5. Condenser fan(s) not running or running backwards.
6. If water cooled condenser then water flow problem.
Hope this helps you get started.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
My laptop boots up every thing comes on but the screen wont light up i plugged in another screen no dice, this has happend b4 and some how i fixed though i cannot remember how that worked. tryed everythign...
You have your power settings to dim the monitor after a period of time passes. On your desktop right click, then properties tab, select screen saver tab, then power tab. Play with the settings until you set what you desire for power saving options. I hope this helps.
May 11, 2009 | Computers & Internet
Dell Laptop Charger, wont charge bat. but keeps computer running.
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
May 07, 2009 | Dell Vostro 1400 Notebook
Jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Apr 09, 2009 | Jet 3 Ultra Power Chair
Whining noise from amp.
hear are couple things to try   try running your power and  (ground) both directly from your battery   to the amp and  to the receiver .. if this doesn't help try purchasing a noise suppressor  and wire your receiver threw this  it should solve your problem
Feb 13, 2009 | Phase Linear UPA424CS Car Audio Amplifier
Shuffle wont charge and wont turn on
Depending on the kind of shuffle, it may just be a simple software reboot.  My firstgen did the same thing for weeks.  If you have a second computer with iTunes, plug it in there, and wait for a message that will tell you if the iPod is corrupted.  Follow onscreen instructions to reinstall software.  you will lose all your music but the iPod should be working again.
Jan 11, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Audiophase MDP-1 Personal MiniDisc Player Logo
63 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Jaime Hernandez
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
