Question about Nintendo Wii Console
One of the remote controls seems to be stuck
Wii sports - batter keeps swinging, pitcher keeps pitching when it is the opponents turn
in bowling, the ball goes backwards instead of forwards
I have reset the remotes, turned power off, then on?? Nothing works
  • kernow78 Feb 08, 2009
    tried everything, works fine on opening screens then during any game up is down, and down is up, and left to right are opposite, if the controller is held up side down it works, how can it be sorted any ideas? thanks
    President:
  • 4,402 Answers
Sounds like to have a stuck button try another remote.
Posted on Jan 22, 2008
Wii sports - baseball - the batter keeps swinging constantly
This sounds like a sensor or controller issue. To eliminate the possibility of it being the sensor unplug the sensor and replace it with two candles the same distance apart as the length of the sensor and light them.
Candles can actually be used instead of the sensor as they emit Infra Red which the controller uses to tell the Wii where it is, in short they do the same job as the sensor panel. If the problem persists, its most likely the controller, try a different controller to eliminate this problem.
Jul 05, 2011 | Nintendo Wii Console
Our wii sport dvd works and you can naviagate to a game, but when you go to swing at a ball it will not work. Batteries are fine.
I have had a problem of this manner before, Does this problem occur with the same controller (wii remote) with each game requiring Movement of some sort. If so, then your Controller's bluetooth is damaged. It's a possiblity someone dropped it or the solder piece became loose in someway. I recommend sending it to nintendo for a replacement or buying another Wiimote (wii remote)
Nov 17, 2009 | Nintendo Wii Sports for Wii
Wii remote works but not for wii sports
If you're wii remote works as a pointer but not when swinging it then it is a problem with the accelerometer inside the wii remote and not the infra red bit on the end. Good news is its usually just stuck as mine was. Nintendo recommend turning the remote upside down and giving it a few taps on the palm of your hand. Worked on mine and saved me £30 as i was about to buy a new one.
Aug 04, 2009 | Nintendo Wii Remote Controller
I need written instructions for EA Sports MVP Baseball for Gamecu
hope these are the right ones
MVP Baseball 2005
BATTING
Z Button Z + A Button = Square to Bunt (release to pull back)
A Button Swing
BASERUNNING
Control Pad Steal / Choose base destination (press toward base you are trying to steal)
Slide Refer to EA SPORTS Big Play Control in Gameplay below.
C Stick Left/Right = Increase/decrease leadoff.
X Button Control runner at 1st
B Button Control runner at 3rd
Y Button Control runner at 2nd
L Button Advance/stop all runners
Z Button Advance/stop all runners
R Button Retreat runner
PITCHING
Control Stick Choose pitch location.
A Button Throw a pitch
X Button Throw a pitch
B Button Throw a pitch
Y Button Throw a pitch
White Button (press and hold) + Directional Pad Up/Down (Left/Right to toggle between bullpens and dugouts) = View Bullpen/Dugout menu
R Button Throw a pitch
L Button + X, B or Y = Pickoff attempt. L + A = Pitchout. L + Control Pad Down = Intentionally hit the batter. L + Control Pad Up = Intentionally walk a batter.
Z Button (Hold) + Control Pad Up/Down = Choose infield/outfield alignment (before pitch). Left/Right to choose a category. Z Button (hold) + C Stick Left/Right = View pitch history, to toggle at bats. Z Button + Control Pad Up/Down = View Bullpen/Dugout menu (Left/Right to toggle between bullpens and dugouts).
FIELDING
Control Stick Move fielder
C Stick EA SPORTS Big Play Control
A Button Throw to home (press and hold to power up, release to throw)
X Button Throw to 1st (press and hold to power up, release to throw)
B Button Throw to 3rd (press and hold to power up, release to throw)
Y Button Throw to 2nd (press and hold to power up, release to throw)
R Button Throw to the cut-off man
GamePlay:
EA SPORTS PURE SWING SYSTEM:
The Strike zone is divided into nine colored squares. Red squares mark the batter's hot zones. Blue squares are the batter's cold zones. Clear squares are neutral for the batter.
Take unprecedented control at the plate by moving the Control Stick during your swing.
-The results of your swing depend on your timing, the location of the pitch, and the direction you move the Control Stick.
-For the best results, move the Control Stick towards the location of the pitch.
-To hit the ball in the air, move the Control Stick Diagonal Up-Left / Up / Diagonal Up-Right while swinging. This increases the chances of hitting a fly ball, but also increases your chances of missing the ball if the pitch isn't up in the zone.
-To hit the ball on the ground, move the Control Stick Diagonal Left-Down / Down / Diagonal Right-Down while swinging. Keep in mind that high pitches are very difficult to hit on the ground.
-To hit the ball to the left, move the Control Stick Diagonal Left- Down / Left / Diagonal Up-Left while swinging. For the best results, use this when the pitch is coming in on the left side of the plate.
-To hit the ball to the right, move the Control Stick Diagonal Right-Down / Right / Diagonal Up-Right while swinging. For the best results, use this when the pitch is coming in on the right side of the plate.
TO THROW A PITCH:
1. Press and hold the button that corresponds to the pitch you want to throw. The bar inside the pitch meter begins moving.
2. Release the pitch button when the bar reaches the end of the pitch meter. The closer your release point is to the end of the meter, the more effective the pitch is.
3. Press the pitch button again when the bar is within the green accuracy zone near the beginning of the pitch cycle to determine the pitch's accuracy.
-The effect of a bad pitch depends on the type of pitch. For example, ineffective fastballs are slower than normal, and less effective breaking pitches are flatter.
-If a pitcher misses the green accuracy zone by a considerable amount, an indicator (red for hot zone, blue for cold zone, yellow for ball, white for neutral) appears to tip off the batter to the location of the pitch.
PITCH SELECTION
Your pitcher's pitch selection appears on-screen. Not all pitchers have the same arsenal of pitches. A pitcher's four-seam fastball is always assigned to A Button. The remaining pitches are assigned to X, B, Y and R Button (though not all pitchers have five pitches).
FIELDING
-If you power up the throw into the red zone, you throw harder, but less accurately, which could result in an error.
-If you select to throw to either a base or the cut-off man before the ball arrives, the fielder begins his throw immediately upon receiving the ball.
NOTE: The CPU automatically adjusts your defensive alignment based on the situation. However, you can override this by choosing the infield and outfield alignments yourself.
EA SPORTS BIG PLAY CONTROL:
Using the all-new EA SPORTS Big Play Control, you can climb the fence to rob home runs, make spectacular diving catches, slide around tags, and more.
FIELDING:
- To dive or stretch for a ball just out of your reach, move the C Stick Left/Right toward the ball.
-To climb the wall to snag a would-be home run or jump for a ball over your head, move the C Stick Up.
-To make a sliding catch, move the C Stick Down as the ball approaches.
BASERUNNING
Timing is the key to a perfect slide. Use EA SPORTS Big Play Control to create havoc on the base paths.
C Stick:
Up = Head-first slide
Diagonal Up-Left/Up-Right = Head-first slide to the left/right side of the bag
Down = Pop-up slide
Diagonal Down-Right/Down-Left = Hook slide to the right/left side of the bag
Up = Dislodge ball from catcher.
May 19, 2009 | EA Sports MVP Baseball 2005 for GameCube
Can't play any games in which swinging is involved
yeah, there is a motion censor in the remote, its a tilt ball. It gets stuck if you swing the remote to hard, to get it unstuck, you have to smack the remote against the palm of your hand button side down.
Mar 15, 2009 | Nintendo Wii Console
On Wii sports the controller seems to work in every respect apart from when trying to swing on a game (e.g. tennis, bowls, golf etc) The buttons work. Also, the controller can go up and down and left to...
well i have the same problem , i have tried everthing so i just feel sorry for u knowing that u cant play on ur Wii so if u do get an answear could u contact me at" lairence-haddad@hotmail.com
Apr 27, 2008 | Video Game Consoles & Games
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
Wii control
unplug the unit from the wall and try it again.
Dec 31, 2007 | Nintendo Wii Console
Wii Remote Problem
try syncing the remote (under the cover on the back of the wii remote where the battery's are there is a circular red button press it then on the front of the wii where you can put your SD card there is a rectangular button press it if that does not work then try doing it the other way around if that does not work keep trying if that does not work i dont know what will
Oct 15, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
108 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
